Thread: 2004 vectra 3.2 sri, wont start unless hit with mallet (genuine)
    Jun 2012
    north wales
    Default 2004 vectra 3.2 sri, wont start unless hit with mallet (genuine)
    Hi guys, dropped a friend off outside the local police station the otherday, went to start my car and it just cranks, no management lights or nothing, car attempts to fire, idles at 600rpm for no more than a few seconds then dies, for some reason i thought fuel pump, checked all fuses, all fine, removed plastic cover under seat, switched ignition on/off, nothing. attempted to crank engine, nothing. struck fuel pump several times with mallet whilst ignition was on, began to buzz, tried to start, fired and idled perfectly. simple diagnosis fuel pump right??? ordered a delivery mileage pump from ebay, fitted it today nothing, attempted to strike pump again nothing. So guys faulty pump? ideas on this would be greatly appreciated.
    Staff.
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Need to check power and ground to pump.
    Fuse?
    Then find relay check this is working. If you have access to tech 2 you can activate fuel pump relay which will help in testing.
    If no click from relay.
    Try using a fused jumper wire between the pins 30&87 on relay control
    See if pump runs?
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    Just to say Ive just done corsa in work that was similar fault. Cut out. Recovered in no fuel pump buzz etc
    After testing I found the BCM ( body control module) to be at fault
    Fingers xd for your bank balance sake it's not same
    Jun 2012
    north wales
    Right guys im getting 12v to the pump, so its highly likely to be this pump, wil attempt to source a new one tommorrow, wil report back. thanks for the replies.
    Jun 2012
    north wales
    Hi guys, sourced a second hand pump from a breakers, car is running just fine. phew.......
  1. Vectra wont start when warm!
    By haye5 in forum Engine & Drivetrain
    Last Post: 14th November 2017, 17:32
  2. Vectra c 2.2 dti wont start
    By latif in forum Vectra C / Signum Car Chat
    Last Post: 27th January 2013, 07:06
  3. vectra c 2 dti wont start
    By ricky192 in forum Vectra C / Signum Car Chat
    Last Post: 28th December 2009, 23:50
  4. vectra wont start
    By damien whiley in forum Engine & Drivetrain
    Last Post: 6th May 2009, 17:30
  5. my vectra wont start help please
    By raymond1711 in forum Engine & Drivetrain
    Last Post: 14th April 2008, 13:04
2004 vectra 3.2 wont start
