Thread: How do you remove the face vents?
    Aug 2010
    Derbyshire
    Default How do you remove the face vents?
    How easy is it to remove the face vents as in the pic below? I also want to remove the one at the window end of the dash, this looks easier than the centre ones. Reason, the bottom slat on two of the vents doesn't move, is this a common problem?
    Mick
    Ely, Cambridgeshire
    60 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    Open glove box, pull dash board strip off towards you (it's only clipped in). Underneath it you'll see two torx bolts on each of the individual side vents and four on the centre set.
    Admin plasma's Avatar
    On the Forum
    247 Post(s)
    Engine : 150
    Mileage : 74000
    if it doesnt move with the others its because its broken... You'll need new vents about £5, or if your really good and careful you can replace the indivdual slats but you'll need another one for that anyway
    Plasma's Tech2 services are now partially open and able to provide services
    Come Join our new forum Insignia Owners.com for all your Insignia chat and needs
    Ely, Cambridgeshire
    60 Post(s)
    Year : 2010
    Or do what I did with two of mine, melt the snapped joint back together with a soldering iron and then melt some extra plastic onto it to make it thicker (I used the edge off an old SD card I didn't need anymore), they're stronger joints than all the others now and took two minutes to do.
    Aug 2010
    Derbyshire
    Thanks very much chaps for your replies.
    I looked at that strip but wasn't sure whether it just unclipped, now I know thanks.
    Mick
    On the Forum
    247 Post(s)
    Engine : 150
    Mileage : 74000
    Quote Originally Posted by Ian-Highlander View Post
    thats fine if thats the control arm, i've repaired two like that myself, but if its the slat swivel point and the point has snapped off theres nothing you can do but replace the slat.
    Regular Member Neve'o's Avatar
    Norfolk
    Vehicle : Vectra SRi 150 Hatch
    Mileage : 69'000
    I used a strong super glue on one of mine, been ok for months now.
  1. face lift chrome vents and rear vents
    By simon1 in forum Vectra C / Signum Car Chat
    Last Post: 21st December 2011, 21:13
  2. Pre-face Lift & Face Lift Auto dimmin Rear View Mirrors
    By Meady in forum Electrical & ICE (including SatNav)
    Last Post: 16th May 2011, 16:25
  3. Pre-face steering wheel / face lift
    By ROCKATANSKY in forum Vectra C / Signum Car Chat
    Last Post: 14th May 2010, 20:57
  4. Pre-face lift vs Face lift performance figures
    By larrysSRI in forum Vectra C / Signum Car Chat
    Last Post: 5th November 2009, 23:11
  5. pre face to face lift?
    By audiorush in forum Styling
    Last Post: 7th February 2009, 13:18
