Thread: Vectra Timing Belt Question
    Regular Member Fitzy-2.0T's Avatar
    Hertfordshire
    Default Vectra Timing Belt Question
    Hello guys got a 52 Plate Vectra a week back and looking through the docs. The car had a timing belt and water pump at 38k the car is currently on 89k when should I consider changing the timing belt. The car is a 1.8
    Full Member Caveman_nige's Avatar
    Jun 2009
    South Coast
    Vehicle : Vectra and a Signum
    Engine : Z18XE,Z19DTH,Z20NET
    every 60k is recommended.. so you should be ok for a while longer. Strange that it was done so early in its life... I did the full belts, pulleys and pump change at 75k on my wifes 1.8 vec. As i was doing it the timing belt snapped so it was close to being a goner, close call you might say.
    Hertfordshire
    Sounds like a lucky escape, yeah thats what I thought little to soon to be changing it but then again some people are over cautious. Is it a pricey job?
    Regular Member Das's Avatar
    Turdsville
    36 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Mileage : 567890987
    60k or every 6 years for the z18xe. £55 for a VX timing belt kit off ebay and about £35 for a genuine water pump. 1.5-2 hours for fitting them.
    Hertfordshire
    Is it really a do it yourself job though?
    Jun 2009
    South Coast
    well yes, I did ours at home having never done one before, there is a sort of How2 on here, its a little vague but it gives you enough to do the job.. I did have to go out and buy an electric impact wrench to get the crank bolt out though, but a great tool that has come in handy since and will continue to do so.
  1. timing belt tensioner question
    By wildchild in forum Vectra C / Signum Car Chat
    Last Post: 7th April 2013, 15:25
  2. Timing belt cover bolts question 1.9 cdti 150
    By ronnie63 in forum Engine & Drivetrain
    Last Post: 7th February 2013, 13:54
  3. vectra timing belt help please
    By mdibb2009 in forum Engine & Drivetrain
    Last Post: 9th July 2011, 13:21
  4. Timing belt interval question
    By collyb in forum Engine & Drivetrain
    Last Post: 28th May 2011, 23:39
  5. timing belt/chain question
    By Baldy in forum Vectra C / Signum Car Chat
    Last Post: 5th September 2006, 12:11
