Thread: MIght have blown my turbo Help!!!
    Full Member
    Sep 2011
    London
    Vehicle : Vectra xp2
    Engine : Z22YH
    Mileage : 83k
    Default MIght have blown my turbo Help!!!
    Hey guys
    Was driving along yesterday decided to put my foot down then i heard a bang, followed by a sound like a blown exhaust.
    limped the car home to find that the turbo intercooler pipe had come off from the EGR end.
    Changed the clip and fitted back, cleared fault code, but the car feels gutless.
    Could someone guide me as to how to work out if its the turbo that has died?
    Cheers guys
    Jan 2012
    Milton keynes
    Trim : M Sport and Design
    Mileage : 38100
    Try taking disconnecting the battery for a few minutes, the ECU is a self learning one, so it might have changed something in its settings?? Just a stab (and cheap) in the dark.
    Full Member
    Sep 2011
    London
    Engine : Z22YH
    Mileage : 83k
    Quote Originally Posted by Chunklamb View Post
    I will give that a try, Cheers.
    Full Member
    Sep 2011
    London
    Engine : Z22YH
    Mileage : 83k
    OK so i disconnected the battery left it for about 5-10 mins, and reconnected the battery, took it for a spin and it sounds like the turbo is spooling up but there is no power it drives flat.
    Any ideas guys?
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Have you checked all the vac pipes in case any have split or burst?
    Jan 2012
    Milton keynes
    Mileage : 38100
    Maybe something easy like a split pipe... can you have someone rev it and you have a listen? It might be quite an obvious hiss...
    I'm a little confused how the pipe blew off in the first place... had it been off recently??
    Full Member
    Sep 2011
    London
    Engine : Z22YH
    Mileage : 83k
    I will have to give that a check. The jubelee clip was not tight so i assume that was why it came off.
    Full Member
    Sep 2011
    London
    Engine : Z22YH
    Mileage : 83k
    hi guys I found the problem one of the vacuum pipes under the inter cooler hose had come out. I have boos t again
    Thanks chunkLamb and tony -1977
    Jan 2012
    Milton keynes
    Mileage : 38100
    Quote Originally Posted by Mrmac View Post
    Glad you got it sorted and it was an easy fix!
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Thanks chunkLamb and tony-1977
    Nice one
    Might be worth replacing all the vac pipes with silicone ones
  1. Turbo blown?
    By the_wave_rider in forum Vectra C / Signum Car Chat
    Last Post: 13th May 2012, 10:33
  2. Turbo Blown
    By dan912 in forum Engine & Drivetrain
    Last Post: 28th June 2011, 20:59
  3. blown turbo
    By raymond1711 in forum Engine & Drivetrain
    Last Post: 18th April 2009, 00:26
  4. turbo blown
    By gary hough in forum Engine & Drivetrain
    Last Post: 25th February 2009, 18:18
  5. Turbo - Help I think its blown
    By awbro in forum Vectra C / Signum Car Chat
    Last Post: 29th June 2008, 23:33
