Results 1 to 10 of 11
Thread: CD70 upgrade
    Mar 2012
    letchworth
    Vehicle : Estate
    Engine : 1.9DTH
    Mileage : 79000
    Default CD70 upgrade
    Hello, im looking at doing an upgrade in my 08 plate, from the cdc 40 opera with the basic screen to the cd70 with the colour navi screen, does anyone know what extras i will need other than the unit and screen? Found a cheap set so might aswell do it
    Regular Member Niall83's Avatar
    Nov 2009
    Belfast
    Very simple lad. I had the same as you and upgraded to CD70 and colour screen. Make sure you get the head unit and screen from the same car as they will be paired together. There is a extra cable think it called RGB that connects between the unit and the screen, it displays the map on the screen. You also need a gps antena which can be got from ebay £10-£15. I fitted the GPS antena at the center speaker under the windscreen vents. Note that you'll lose the DAB.
    Mar 2012
    letchworth
    Vehicle : Estate
    Engine : 1.9DTH
    Mileage : 79000
    Cheers for that, its a bit rubbish about the dab, think id rather keep that than have the nav. I take it the cd70 doesnt have the dab option on it then?
    Dec 2011
    Seaham
    No DAB option, but if you get a later one, you can have an Aux In.
    Mar 2012
    letchworth
    Vehicle : Estate
    Engine : 1.9DTH
    Mileage : 79000
    Think ill just stick with the cdc40 and keep the dab, just use my generic satnav system stevesteve lol. Would the colour display work with my cdc40?
    Nov 2009
    Belfast
    Yes the colour display will work BUT the colour display needs unpaired from the CD70 and same with your GID and CDC40. Then the colour display (CID) then needs paired (programed) to your CDC40. Security codes for each Radio Display pair is needed.
    Mar 2012
    letchworth
    Vehicle : Estate
    Engine : 1.9DTH
    Mileage : 79000
    One last thing would i lose the hands free if i fitted the cd70 with the cid?
    Nov 2009
    Belfast
    What kind have you got
    Mar 2012
    letchworth
    Vehicle : Estate
    Engine : 1.9DTH
    Mileage : 79000
    The standard hands free within the cdc40 opera
    Wirral / ellesmere port
    12 Post(s)
    Vehicle : insignia tourer
    Trim : elite
    Engine : 2.0 cdti 160
    Year : 2011
    Quote Originally Posted by barneytravolta View Post
    have you got the factory bluetooth,is that what ya on about ?
    if so then yeah it will still work but as mentioned previously it will all need re programming if your fitting a cid
  1. CD70 upgrade
    By patch22 in forum Electrical & ICE (including SatNav)
    Last Post: 29th December 2011, 02:38
  2. CD70 upgrade
    By TopRod in forum Electrical & ICE (including SatNav)
    Last Post: 22nd October 2010, 21:51
  3. CD70 Upgrade
    By r.bailey63 in forum Electrical & ICE (including SatNav)
    Last Post: 10th October 2009, 12:29
  4. Cd70 Nav Upgrade
    By LOCKSTOCK in forum Electrical & ICE (including SatNav)
    Last Post: 22nd July 2008, 16:25
