Thread: Cleaning MAF sensor
    Regular Member marky2027's Avatar
    Northumberland
    Default Cleaning MAF sensor
    I had intermittent juddering on light acceleration on my 1.9 cdti. I have cleaned the boost sensor, EGR, throttle body, mesh filter off boost control solenoid and replaced vac pipes with silicone ones. The car absolutely flies now but very (and I mean very occassionaly) I think the judder may still be there. If it is then it is very slight. I was thinking about cleaning the MAF sensor just to be sure. I have had it off the car and can't see anything sinister. I have read that the whole lot should be soaked in IPA and then dried before re-fitting. is this right or will carb cleaner be OK? Is it ok to clean the entire unit except the electrical connector on the side? or should I just leave well alone?
    Full Member
    Mar 2007
    Finland
    I would recommend CRC MAF Cleaner for the job: CRC Mass Air Flow Sensor Cleaner
    Northumberland
    Cheers. Didn't realise you had to use a dedicated cleaner. Have you or other members on here used it? Is there any chance of damaging it if i'm too too rough? Could GT 85 be used as this is an electrical cleaner?
    Should cleaning this be part of routine maintenance like the EGR etc?
    Full Member
    Mar 2007
    Finland
    I have used it and it didn't do any damage. Just be careful: don't touch the sensor, only spray it with the cleaner and let it dry. I would only use the dedicated MAF-cleaner, because MAF's aren't cheap to replace. I wouldn't touch it with any cleaner if I'd know it is working fine, only if there is something wrong (contaminated MAF due to faulty air filter etc.).
    Northumberland
    Might just leave it and see how it goes then.
    Northumberland
    Well after driving in traffic the dreaded hesitation returned once or twice. Might be forced into trying this now
  1. Anyone tried cleaning the MAF sensor?
    By dariousa in forum Engine & Drivetrain
    Last Post: 1st July 2012, 21:59
  2. car is slower after cleaning the boost sensor!?
    By IrishVectra in forum Vectra C / Signum Car Chat
    Last Post: 5th June 2012, 18:36
  3. sensor cleaning
    By wildchild in forum Vectra C / Signum Car Chat
    Last Post: 21st September 2011, 21:53
  4. cleaning the maf sensor with wd40
    By luke.oldham in forum Engine & Drivetrain
    Last Post: 8th February 2011, 22:36
  5. Cleaning Boost Sensor, 1.9CDTi ????
    By mpc in forum Vectra C / Signum Car Chat
    Last Post: 8th July 2010, 23:11
vectra c maf sensor cleaning
