Results 1 to 10 of 14
Thread: power from the cigerette lighter.
    Feb 2011
    Mansfield, Nottinghamshire
    Default power from the cigerette lighter.
    Hi,
    Could someone tell me if its possible to have my Parrot handsfree kit and have a strip of footwell lights in each footwell powered by the cigerette lighter?
    Here is the link for the footwell lights,
    http://www.ebay.co.uk/itm/LED-Car-St...ht_1003wt_1185
    Thanks in advance
    Mark
    Feb 2011
    Selby
    Quite probably. IIRC it's a 10A fuse - which I doubt your LEDs and handfree kit together get anywhere near. Just have a look at the current ratings on the things you plan to plug in.
    Feb 2011
    Thanks for the quick reply. i shall take a look later.
    Regular Member Munkey's Avatar
    Jun 2012
    United Kingdom
    Don't forget things that you may plug into the cigarette socket too. As long as you don't exceed fuse rating it should be fine
    Feb 2011
    Is there anywhere else i could connect the footwell lights? Don't want to risk putting too much onto the lighter.
    Jun 2012
    United Kingdom
    could use the light in the glove box or run the power line from a rear cigarette socket if you have one?
    Feb 2011
    yeah i have one in the back, I may do that just to make sure I don't overload the front socket. Would the lights come on when I open the drivers door, and dim when the door shuts?
    Jun 2012
    United Kingdom
    No mate, you would need to integrate the lights into the existing light circuit for that. Probably not too difficult as will only be a feed off the existing, only problem would be which lights and the running of the cables.
    Personally I would go from the roof light at the front and down the passenger pillar, but if you don't get everything back properly you will create rattles right above your head...
    Feb 2011
    I may not bother with them then, I don't want to create rattles. I was hoping that if i connected them to the cigarette lighter they would dim when the door was shut.
    One day I may try this one
    Thanks for your help.
    Forum Moderator & Events Team davedrinks's Avatar
    Sep 2010
    Luton
    20 Post(s)
    Vehicle : Vectra Hatch
    Engine : 1.8VVTi 16v
    Mileage : circa 28K
    There is a How2 for wiring your Footwell LEDs in so they are linked to your interior lights so they do what you are wanting - linky
    HTH
    Mods : Insignia Washer Jets,Boot & Footwell LEDs,Reverse Cam,Pioneer AVH-3200BT,Pioneer TS-Q172C(front),Alpine MRVT407 V12 Amp,Alpine SBE-1243BR 12" Sub,In Car Freeview TV,Heko Wind Deflectors,Airbox mod,K&N Panel Filter,Irmscher Boot Spoiler,Angel Eyes, 50W 5K HIDs, 30mm Lo lowering springs, Eyebrows,17" Fox Alloys,Powerflow Stainless Steel dual exhaust. Winner-Best I.C.E-Heritage Centre Meet 2013
  1. cigerette lighter
    By big jon in forum Electrical & ICE (including SatNav)
    Last Post: 8th March 2012, 22:27
  2. Power/lighter socket..
    By nikroc in forum Bodywork & Interior
    Last Post: 26th January 2012, 17:18
  3. No power from cig lighter
    By beethamwest in forum Vectra C / Signum Car Chat
    Last Post: 24th April 2010, 10:11
  4. When does the front cig lighter power up?
    By John LE in forum Electrical & ICE (including SatNav)
    Last Post: 21st February 2010, 01:03
  5. Power From Cigarette Lighter
    By PSV6 in forum Electrical & ICE (including SatNav)
    Last Post: 25th January 2007, 17:23
