Results 1 to 10 of 14
Thread: Vectra rear interior light not working
    Regular Member Steve 100's Avatar
    Apr 2012
    Grimsby, Lincs
    confused Vectra rear interior light not working
    Managed to get a rear light for my vectra from the breakers. Pulled the roof lining down and found the cable and connected up the light to try it. It didn't work. Am I missing something? Is there a fuse to fit/replace?
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Sounds daft, but have you tried another bulb? And is there power at the bulb connections (check with multimeter)
    Regular Member coldo's Avatar
    Scotland
    There are two cables... Both of which fit the light... One has two pins in it which is actulay for the reverse sensor kit I think and the other has three pins in it which is for the light.
    My 2004 LS only had the two pin cable so I had to solder cable in...
    My 2004 SRI has both so fitting the light was easy...
    Check out the how to's as this should help with fitting the ligh either way.
    Apr 2012
    Grimsby, Lincs
    Yeah I should check the bulbs. I dont have a multimeter. I wasn't aware there are two cables. I saw I bigger one.
    Thanks for the answers.
    Scotland
    the front light is the same as the rear so take the plastic over off that and take one bulb out and use that to test if they are working ok.
    This was the two cables I found in my SRI if that helps....
    Scotland
    The biger cable with the 4 ribon lead whcih says cealing dome is the one you want to use...!
    Apr 2012
    Grimsby, Lincs
    Thanks for that. I'll have a look again later.
    Full Member Robsey's Avatar
    North East Cheshire
    22 Post(s)
    Trim : Energy
    Mileage : 131,000
    Failing that, you could simply run 4 wires from the front interior light to the rear one.
    This is what I did, as my "Energy" model did not have any ribbon cables in the rear of the roof lining.
    I was too tight to part with £40 for a ribbon cable from the stealers, when 4 wires would do the same job free of charge.
    Apr 2012
    Grimsby, Lincs
    That sounds like a plan!!! Was it fairly easy baring in mind I am no electrician??!!
    Scotland
    My LS didnt have the wiring. I just used the how to guide on the site for hard wiring the rear ligh... Works a treat and easy to do... Took me 40 minutes all in including dropping the head lining.
    http://www.vectra-c.com/forum/showth...-(without-loom)
  1. interior light not working
    By chubby in forum Vectra C / Signum Troubleshooting
    Last Post: 2nd September 2013, 20:26
  2. Zafira Rear Interior Light in a Vectra
    By Paul_NI in forum Vectra C / Signum Car Chat
    Last Post: 21st January 2013, 18:39
  3. I now have a working rear interior light
    By rob warrington in forum Electrical & ICE (including SatNav)
    Last Post: 7th January 2012, 16:55
  4. Rear door - No electric window or interior light but Central Locking working!
    By siw8158 in forum Electrical & ICE (including SatNav)
    Last Post: 25th February 2011, 23:41
  5. Vectra rear interior light
    By parsco in forum Parts for sale
    Last Post: 13th July 2010, 11:08
vectra c rear interior light
vectra c interior light not working
vectra c interior rear light
inside the front lights on a astra mk4
has my 2005 vectra c got the wiring loom for interior rear light
