Thread: Dashboard dead help!!!!!
    Mar 2007
    S Wales
    Default Dashboard dead help!!!!!
    Started the carthis morning to find the instrument display was almost completely dead. So mostof the lights don’t work, rev counter doesn’t work, Speedo doesn’t work, temp gaugedoesn’t work, fuel gauge doesn’t work, etc.
    When I turn the key the engine light comes on and then goes off when the enginestarts and the "door open" light stays on all the time.
    Its a vectra 2006 sri 1.9CDTI.
    As some of the lights work was wondering if this is something major! Help assoon as possible please.
    Middlesex
    Trim : SRI
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 100k
    Not so uncommon..
    So first things to check:
    There are two fuses- and I cant remember the numbers - that you need to remove and clean... Memory is telling me 17 and 23 but im not 100%, will check for you.
    Remove and clean the main ABS multiplug under the bonnet. Use ONLY contact cleaner, not WD40 as that leaves a film.
    Remove and clean (same as above) the multiplug on the back of the CIM module.
    If that doesnt work its likely to be a CIM failure but the above has been known to fix this many times.
    A
    Middlesex
    Trim : SRI
    Mileage : 100k
    Ok - so its fuses 17 and 26.. Check these and replace TBH - better than trying to clean etc.
    Mar 2007
    S Wales
    Quote Originally Posted by AntSSSS View Post
    Not so uncommon..
    A
    Thanks for thequick reply.
    Ill check on the fuses at lunch time. If its not that then I may need your helplocating the ABS and CIM connections.
    Just another fun thing to fix on this car! Alternator was the most fun tochange! lol
    6 Post(s)
    When it once happened to me, I pressed the trip reset button and the dash came back to life.
    Mileage was approx 5 miles less than the stereo trip computer reading though.
    Regular Member Das's Avatar
    Here
    33 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Heres where the ABS plug is, circled in blue, just behind the battery box.
    Mar 2007
    S Wales
    Thanks for the help I shall take a look at lunch or tonight and get back.
    Regular Member Robsey's Avatar
    North East Cheshire
    Trim : Energy
    Mileage : 101,000
    Fuses 17 and 26 are for the infotainment system display
    Fuse 12 is for the battery overload / over-voltage relay... very common failure, however you would normally lose interior lights.
    Fuse 10 is for the CIM itself
    Beyond here you would need to check 3 modules.
    First the ABS connector - it is prone to corroded / dirty pins on pre-facelift Vectra's.
    Then check that all steering collumn earths are clean and secure.
    Finally - I would recommend a diagnostic check, to confirm that the CIM (collumn integrated module) or the ECM (Engine Control Module) have not gone belly up.
    The tell tale for the ECM, is that it will NOT communicate with the diagnostic tool. You would need Tech 2, Op-Com or Vauxcom to verify if there are any module specific trouble codes and which modules are communicating.
    Oh - and if diagnostic does not give any joy, then check the connector on the circuit board of the instrument panel for dry solder joints. Also not uncommon for instrument only problems.
    Regular Member Vectra Meldrew's Avatar
    Hertfordshire
    Exactly what happened to me about 6 months ago! Drove around with dead dash all day worrying how much a new cim and programming was gonna cost, then for some reason I just poked the trip button and... Bingo! -Back to normal . Never happened again.
    Mar 2012
    Norway
    Same happened to me.
    I disconnected +12V from battery for 5-10mins, then everything was back to normal.
    Did'nt try the trip button though.
  1. dashboard dead (no rev, speedo, lights)
    By Swatty in forum Electrical & ICE (including SatNav)
    Last Post: 7th December 2011, 13:31
  2. Dead dashboard.
    By Bob Acid in forum Electrical & ICE (including SatNav)
    Last Post: 22nd July 2011, 16:29
  3. dashboard bit
    By porthy-t in forum Styling
    Last Post: 19th January 2010, 19:18
  4. Dashboard Contents ?
    By 742-xx in forum Bodywork & Interior
    Last Post: 9th July 2007, 12:17
  5. Marble in my dashboard ?
    By 742-xx in forum Suspension, Wheels & Brakes
    Last Post: 7th July 2007, 12:49
