Results 1 to 10 of 18
Thread: Loss of power steering.electro-hydraulic power assisted steering symbol displayed.
    Jun 2009
    Middlesex
    Default Loss of power steering.electro-hydraulic power assisted steering symbol displayed.
    Started the car up this morning and had no power steering.Had a steering wheel warning symbol on instrument panel.Looked in handbook and says it indicates problem with Electro-Hydraulic Power Assisted Steering.Went out later and power steering has returned and warning light has gone out.
    Anyone got any ideas what the problem may be?
    Regular Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 iVtec
    Mileage : 65500
    Alternator on it way out most likely. Test the battery with the car running, should be between 13.5 and 14.4v.
    Jun 2009
    Middlesex
    Thanks for responding but why possibly the alternator when i've lost my power steering.What's the connection?
    Yer Maws Bedroom
    40 Post(s)
    Engine : 1.8 iVtec
    Mileage : 65500
    Its Electro Hydraulic Power Steering, or Power Assisted Steering, its takes loads of Load to power it properly. Have you ever noticed at night when your stationary(with the headlights on) and turn the steering wheel and the lights and the GID dims or flicker? The Power steering does take quite a load to make it run on the Vec.
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 142000
    Jun 2009
    Middlesex
    Sorry but the thread above did'nt take me anywhere.Just trying to get my head around this.So being electro-hydraulic if requires power to drive motor/pump does it and is not driven by a belt.
    Yer Maws Bedroom
    40 Post(s)
    Engine : 1.8 iVtec
    Mileage : 65500
    Yup that's pretty much spot on. Old systems were driven off the the Aux Belt that powered a pump that pumped the fluid that powered the steering. From what I can see the system is an All In One type with the pump and reservoir sitting on top of the steering rack and the pump being powered by electricity directly from the battery. BTW it may also be worth while checking the fluid level too.
    Jun 2009
    Middlesex
    Thanks for that.As you say it might be worth checking fluid level.How do i go about checking this on the 2.2 (04 reg) Elite.Am i right in saying access is via drivers wheel arch and i have to remove in wheel arch liner ?
    Thanks Dobs
    Regular Member Exclusive BV's Avatar
    West Midlands
    yep the pump requires a 14v feed to work correctly.
    If the pump and alternator check out ok, Another part that can cause issues is the angle sensor, which monitors the steering wheel position and tells the pump to speed up and provide power assistance.
    There may be a fault code stored in the ecu which you can get read
    Yer Maws Bedroom
    40 Post(s)
    Engine : 1.8 iVtec
    Mileage : 65500
    Some Vecs have the PS reservoir in the inner wing, some have them on top of the steering rack behind the engine.
  1. Steering wheel light & loss of power steering
    By the_wave_rider in forum Vectra C / Signum Car Chat
    Last Post: 3rd August 2012, 14:09
  2. electro hydraulic power assisted steering warning light
    By dodus in forum Electrical & ICE (including SatNav)
    Last Post: 12th July 2012, 19:48
  3. Loss of power steering
    By scrivy in forum Engine & Drivetrain
    Last Post: 25th June 2012, 21:08
  4. electro-hydraulic power-assisted steering light
    By davidsi in forum Engine & Drivetrain
    Last Post: 31st May 2011, 21:39
  5. Power Assisted Steering
    By S888 SRB in forum Suspension, Wheels & Brakes
    Last Post: 27th August 2007, 21:12
hydraulic assisted steering symbol
electro hydraulic power assisted steering vauxhall vectra c
electro hydraulic power steering vectra c
