Results 1 to 10 of 25
Thread: Airbox mod
    Jul 2011
    UK
    Year : 06
    Default Airbox mod
    Ok so I've done the mod when I got the car I've also removed the front intake pipe now what am going to do is drill a hole in the rear and put a vent in then I want to put another air feed in the front left hand corner of the air box but what should I use for the feed
    Jul 2011
    Daventry
    Why do you want to do this??
    As an ex Audi Motor Sport Diesel Tech responsible for electronic tuning I cant understand what you are trying to achieve, you will gain nothing in power, in fact you may lose a couple of f/lbs of torque and just increase noise.
    Regular Member 19CDTi's Avatar
    Jul 2009
    Perth, Scotland
    Quote Originally Posted by marc vectra sri View Post
    Marc,
    There's a user called Signum-steve (or similar) who added a 2nd cold feed from the left of the grille into the airbox. He had good things to report about this. I'd check out silicone or PVC air ductinge online, ebay have it by the metre and you can specify what diameter you wish.
    HTH
    Stuart
    Sep 2010
    I did the 'airbox mod', removed the baffle thing and fitted a K&N to my other Vec,.... can honestly say I noticed nothing. No difference in noise power mpg or driving feeling. As tatters40 says,.. what's the intended result?
    Jan 2012
    Lancs
    Vehicle : Signum Design 1.9cdti
    I've got 2 x 40mm cold air feeds going in 1 @ bottom front left & 1 @ bottom front side entry, right hand side. Both have 40mm pipes going to cold air feed, after this mod & the internal mod, the engine breathes much much easier, revs rise much quicker and the whole feel is much more responsive. Once upto around 3000 rpm the thing flies pretty damn quickly.
    Jul 2009
    Perth, Scotland
    Quote Originally Posted by pthres View Post
    Similar, nay VERY similar, to the feedback given by another 2 users at least. I am also interested in this mod but am still in the results research phase....
    Jul 2011
    UK
    Year : 06
    Thanks for the info the reason why is I've taken off the front intake off the air filter and now give a notice roar deep noise so am thinking add some cold air direct into the filter to keep the noise instead of the normal intake pipe
    Jul 2009
    Perth, Scotland
    Marc have you taken the top and bottom pipes off the inside of the airbox? Top one is next on my list, then probably to drop the bumper and investigate where I could route a 2nd feed - in red silicone of course
    Stuart
    Jul 2011
    UK
    Year : 06
    Quote Originally Posted by 19CDTi
    Stuart
    Top and bottom pipes what's these I've taken out the funnel inside the air box (air box mod) and the front pipe that goes from the air box to the front of the car
    Jul 2009
    Perth, Scotland
    So you're taking air from the engine bay?
    It was my understanding that without a heatshield or enclosure that would detriment performance due to the air temp being higher (and therefore less dense) in the engine bay than the cold feed from the grille....?
    Not an issue if you're after the noise rather than the beef. I will definitely be putting a cold feed rather than engine bay feed but each to their own lol
    Where abouts are you anyway Marc? Sounds like we have modding preference similarities, I'm sure our paths have crossed on this forum a few times.
    Stuart
  1. Airbox mod.....part deux!!! (rip off of VXR280 airbox mod)
    By paul_sri150 in forum Diesel Engine related
    Last Post: 30th January 2012, 22:50
  2. Airbox Mod!!
    By R-ford_Vec_C in forum Vectra C / Signum Car Chat
    Last Post: 2nd June 2010, 14:15
  3. airbox mod
    By andy_hare in forum Vectra C / Signum Car Chat
    Last Post: 10th January 2010, 14:29
  4. Airbox mod(But Why)
    By stanian in forum Petrol Engine related
    Last Post: 7th May 2009, 09:49
  5. Help with the airbox mod?
    By strothrc in forum Diesel Engine related
    Last Post: 9th April 2009, 15:10
