Thread: Intermittent cruise control & oil can light...HELP NEEDED
    Regular Member simmo3187's Avatar
    Jul 2010
    North Wales/North West Border
    Engine : 3.0 V6 CDTI
    Default Intermittent cruise control & oil can light...HELP NEEDED
    Hi all
    I hope someone is able to help me with the following...
    Over the last 2 weeks I have had this a few times when driving home from the girlfriends house which is about 40 miles away
    2 seperate issues..
    First one is the oil can light....Driven all the way to hers no problem then 4 hours later when I get back in the car about 10 miles into my journey home the light comes on
    This has happened twice now on 2 occasions but the oil level seems fine?
    The second one is the cruise control...
    Over the last week I've noticed it has been starting to turn itself off on its own? Tonight however it decided not to turn on so I left it 10 mins while driivng then it worked? Any ideas?
    If anyone can point me in the right direction that would be great thanks
    Its a 07 plate 1.9 cdti vectra c
    Jul 2010
    Anyone?
    Nov 2010
    East Midlands
    6 Post(s)
    Trim : design
    Re Cruise control - I fixed mine by repeatedly pushing the cc button on the end of the stalk - its usually dirty switch contacts and by doing this seems to clean them and improve the contact. Also try http://www.vectra-c.com/forum/showth...ghlight=cruise Looks complicated but easy to do Also check the switch connections on your clutch and brake pedals
    Nov 2010
    East Midlands
    6 Post(s)
    Trim : design
    Re- oil light coming on - is it the oil can on its own or the oil can with a spanner through it - the oil can on its own indicates a problem with the oil pressure system could be oil pump or more often the oil pressure switch - check connections to the switch - if its the oil pump this could lead to serious damage to your engine.
    If its the oil can with spanner this is the service indicator and means your car is ready for a service or the light needs resetting.
    Jul 2010
    Thanks very much... It's just the oil can with no spanner
    Its really strange as one night I checked the level and it seemed a tad low then the next morning it seemed fine?
    Do you think a code reader could tell me which one it is? Ie the pump or pressure switch?
    Or best to get it in the garage?
    Nov 2010
    East Midlands
    6 Post(s)
    Trim : design
    Its not the oil level its the pressure that the oil is running at - a code reader will probably pick up a faulty oil pressure switch - but not sure that it would indicate low pressure. Perhaps another member will come along and advise on that. You need to get the oil pressure checked pretty quickly as you can soon damage your engine running it with at low pressure. As far as your oil level - you can get a different reading on your dipstick when the engine is hot and when cold - check it in accordance to the owners handbook. HTH
    Jul 2010
    Thanks for your help mate
    Really appreciated
    Going in the garage tomorrow so hopefully it's just the switch
  1. help needed with cruise control please
    By deano1 in forum Electrical & ICE (including SatNav)
    Last Post: 31st December 2012, 11:01
  2. Cruise control intermittent working, ( faulty CIM possible?)
    By jon1.9cdti in forum Electrical & ICE (including SatNav)
    Last Post: 3rd June 2012, 23:32
  3. cruise control Cockpit light
    By Betus in forum Bodywork & Interior
    Last Post: 20th September 2011, 01:18
  4. Intermittent Cruise Control Problem
    By Bobarache in forum Electrical & ICE (including SatNav)
    Last Post: 19th December 2009, 19:14
  5. Cruise control dashboard light
    By superstuper in forum Electrical & ICE (including SatNav)
    Last Post: 8th September 2008, 11:17
