Thread: Rear brake caliper problem
    Mar 2007
    wrexham
    Vehicle : Vectra c
    Trim : SRI Estate
    Engine : 1.8 VVTI
    Year : 06
    Default Rear brake caliper problem
    Evening all. I had a problem with the near side rubber seal around the piston when I was changing the rear pads and discs this afternoon. The rubber seal was turning with the piston as I pushed it in and I ended up splitting it. Picture below.
    Does anyone know if I can get this seal separately or do I have to buy the whole caliper ? Any part number would be appreciated. Thankfully the other side turned out to be a doddle
    Thanks in advance
    Andy
    Jul 2009
    barnsley,yorkshire,GB
    Engine : 20 Dti
    Hi S
    you can buy a caliper seal kit,you get the piston seals and the outer bellows,don't know the part no.
    Jul 2009
    Engine : 20 Dti
    Administrator plasma's Avatar
    On the Forum
    357 Post(s)
    Engine : 150
    Mileage : 74000
    vauxhall sell the seal on their own, iirc the 314's front seals were £7 a pop, so the rears should be cheaper
    Mar 2007
    wrexham
    Vehicle : Vectra c
    Trim : SRI Estate
    Engine : 1.8 VVTI
    Year : 06
    Cheers , looking around the internet I think the part could be 9318802. Will check at dealers tomorrow and order.
    Mar 2011
    Bedworth
    Vehicle : Vauxhall Signum
    Trim : Elegance
    Engine : 1.9 CDTi 120PS
    Year : 06
    Mileage : 115000
    Hi mate, did you get new seals for the rear brake pistons in the end?
    I noticed one of mine had a small split in it when I was changing the rear discs and pads.
    Chris
    Mar 2007
    wrexham
    Vehicle : Vectra c
    Trim : SRI Estate
    Engine : 1.8 VVTI
    Year : 06
    Bought one, cost £6.72. They had to order it in so shall be picking it up tomorrow ( Friday ) Part number is definitely 93188002
    Mar 2011
    Bedworth
    Trim : Elegance
    Year : 06
    Mileage : 115000
    Cool, thanks for that.
  1. Rear brake Caliper
    By scoles1 in forum Suspension, Wheels & Brakes
    Last Post: 16th February 2011, 23:16
  2. Rear brake caliper
    By NI-2.2SRI in forum Handling & Braking
    Last Post: 16th March 2009, 19:33
  3. rear brake caliper
    By jerc in forum Suspension, Wheels & Brakes
    Last Post: 22nd October 2007, 13:56
