Thread: 2.2 direct fuel pump and fuel pressure regulator
    Jul 2012
    newcastle upon tyne
    Default 2.2 direct fuel pump and fuel pressure regulator
    im thinking about getting a 2.2 direct sri but put off by all these horror stories about the fuel pump and fuel pressure regulator failing. how common is this fault?? does this happen to evey single one of them?? and would i be able to put a performance fuel pump and fuel pressure regulator on to stop this happening? also would it be easy enough to do or would it need other mods too?
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 142000
    hi welcome to the site i take it you have read some threads on here
    Jul 2012
    newcastle upon tyne
    i've read quit a bit on here and been searching on google for few days.
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Mileage : 142000
    there are a few threads regarding the fuel pump and the regulator on here
    heres one
    http://www.vectra-c.com/forum/showth...direct-misfire
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Mileage : 142000
    you can watch a watchdog video on post 6
    http://www.vectra-c.com/forum/showth...l-engine-fault
    Regular Member Paulwr's Avatar
    Mar 2012
    Ormskirk, Lancs
    Vehicle : Astra H 1.8 VVT
    Trim : SRi XP 3dr
    Engine : Z18XER
    Mileage : 12k
    Hi mate.
    I drive a 2.2 direct SRi. It has had the FPR replaced under the Vx recall and has the improved continental pump on it.
    Touch wood, it runs just fine and for the money they are exchanging hands for you can't go wrong even if you do have to shell out for these 'Achilles heel' potential problems with this engine.
    Make sure the one you buy has had the FPR done and has the improved pump on it, if it doesn't then use this as a bargaining chip to drive the price down and get it done yourself, then you can enjoy your car.
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Mileage : 142000
    there are many threads
    http://www.vectra-c.com/forum/search...earchid=140319
    sorry to put you off the car
    just thought you would like the info
    Mar 2012
    Ormskirk, Lancs
    Trim : SRi XP 3dr
    Engine : Z18XER
    Mileage : 12k
    Quote Originally Posted by vectra ste View Post
    There are hundreds of threads on this site about problems with all variants of the vectra, that is one of the reasons this site is here.
    I agree this engine has its known issues, as do all other engines, but at least knowing about the problem lets you do something about it and at the end of the day it is relatively cheap and very easy to fix.
    The threads did not put me off buying this engine variant and I enjoy the car very much.
    Of course my stance is biased but as I have said I love my 2.2 direct. LOL.
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Mileage : 142000
    im sure the op will make his mind up
  1. Replies: 3
    Last Post: 21st July 2012, 22:02
  2. 2.2i direct injection fuel pressure regulator
    By alanatrr in forum Engine & Drivetrain
    Last Post: 3rd August 2009, 23:23
  3. H.p fuel pump pressure regulator problem 2.2 direct
    By Dobs in forum Engine & Drivetrain
    Last Post: 3rd August 2009, 18:06
  4. Replies: 4
    Last Post: 22nd June 2009, 13:56
astra 1.8 vvt 2009 fuel regulator fault repair
