Results 1 to 10 of 18
Thread: cdti warm idle and smoke
    northampton
    Default cdti warm idle and smoke
    need some help on this. ! 46K 150 bhp CDTI. this car has had a lot parts replaced to try and slove a fault by the dealers. The problem is after the car has been resting for over 2 hours it starts up ruff and above ave. smoke comes out the back. I can stop this by either v lightly touching the acc pedal or un-plugging either the MAF, boost sensors to go to basic settings. Both of these sensors are new. the idle and smoke disappear within 10 secs and all seems ok.
    The car does not do this when on a cold morning start and does not smoke etc after leaving it for 8 hours just anything upto 6 hours!! It,s not the turbo or injectors as that has been done as well.
    Do the CDTI have a idle control valve or something i can try!?!??!?
    Please help, the dealers are playing around now and no faults are found...
    member of the smoke patrol 230bhp+
    send a email to mark gsi he may have some idea what it may be
    id start screaming at the dealer to get you a new engine just to put the wind up them to find the prob
    thanks for the Pm..
    i'd try either the coolant temp sensor, as it doesn't do it when it's cold, and yes it does have an idle control valve.. look back right on the engine where the intake hose enters the engine..the valve is there..
    sounds like cronic over fuelling on startup cold cycle.. they need to examine the fuelling cycle and get some breakout feeds of values out of the coolant sensor..
    Regular Member Ian's Avatar
    York
    Could very well be the fuel pressure too. Cold, a nice rich mixture is good, but when warm it smokes due to excessive fuel.
    yep, and that fuel shot is regulated by the coolant temp sensor.. too cold a reading will increase the reading to the ecu making it overfuel...that will give you the black smoke overfuelling..and overfuelling will result in an uneven idle speed as the engine tries to burn excess fuel..
    the only things that effect the burn on the diesel is the amount of avaliable air and the amount of fuel to burn..
    told you marks the one with the spaners
    must ask mark is the slay packed
    got my list and checked it twice..
    hope the slay has fog lights fitted
    York
    thats basically what I was getting at, but there are other systems that affect the fuel pressure, for instance a partially clogged return fuel line. I would always have the fuel pressure checked as well as a full check of the sensors.
    northampton
    the coolant temp sensor has been replaced as well. On the old petrol engines there use to be a problem when a small hole got blocked up and it affected the idle does the cdti have anything like this? I have had the throttle control off today and given it a wipe around but but that looked ok, What was caked in black dry soot was the area around the EGR but i have carefully got this clear and clean but it still is the same. The question is should it smoke on a 45K engine on a mid-day startup???/
  1. CDTI lumpy idle & smoke?
    By bigdave1701 in forum Engine & Drivetrain
    Last Post: 17th September 2012, 13:48
  2. Very lumpy cold and warm startup and grey smoke
    By cheekylemon in forum Engine & Drivetrain
    Last Post: 5th July 2011, 22:33
  3. 2.2DTi needs to idle on stop to restart when warm?
    By MadMe in forum Vectra C / Signum Troubleshooting
    Last Post: 24th September 2007, 09:09
  4. Vectra GSI 3.2V6 Warm Idle Problem
    By pswfps in forum Engine & Drivetrain
    Last Post: 1st March 2007, 19:43
  5. ruff idle and smoke cdti
    By km101 in forum Engine & Drivetrain
    Last Post: 21st December 2006, 20:55
