Thread: Swap cd70 GID to CID
    Regular Member rockonoli1's Avatar
    Telford
    Default Swap cd70 GID to CID
    We have had a 06 plate Vectra traded in at work that has a colour display, was thinking of swapping it for my monochrome one in my siggy which is a 55 is it a straight forward swap the display or do I have to change wiring? Cheers in advance Stu
    Regular Member messermitch's Avatar
    Aug 2009
    Yorkshire
    Engine : 1.9Cdti 150
    Quote Originally Posted by rockonoli1 View Post
    Hmmm. I'l watch this one with interest.......
    Jan 2010
    Hucknall, Nottingham
    there are loads of posts about this on the forum, have a look around
    THe main point is that you'll either need to Tech2 the screen to divorce it from the old head unit and join it to yours or you could get a head unit and screen together and save the bother.
    The main difference is te fact that the colour screen needs an RGB cable too, but if you've got a CD70, it should just be a straight swap
    Telford
    Yeah mine is a cd70, have seen the divorce and marry process mentioned but I'll swap both, just didn't know if I would have the rgb cable
    Regular Member Robsey's Avatar
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    No the RGB cable is a separate item.
    When you get the CID, also grab the RGB cable - the other car will not need it.
    Read my response to your thread "hyjack" - it is very long to re-type here.
  1. Swap NCDC2013 with CD70
    By Teapot in forum Electrical & ICE (including SatNav)
    Last Post: 4th January 2013, 01:41
  2. CD70 with bluetooth - straight swap?
    By damers2000 in forum Electrical & ICE (including SatNav)
    Last Post: 21st September 2012, 20:08
  3. cd70 and cid swap
    By neill in forum Vectra C / Signum Car Chat
    Last Post: 19th April 2012, 21:45
  4. cd 30 swap for cd70
    By Smudger34 in forum Electrical & ICE (including SatNav)
    Last Post: 12th January 2012, 18:53
  5. Swap CD70 for DVD90
    By Peabrain in forum Electrical & ICE (including SatNav)
    Last Post: 20th April 2008, 22:33
swapping cd70 gid for cid
