Thread: help p2279 grrrrrrrr
    Jul 2012
    sheffield
    Vehicle : vectra
    Trim : sri
    Engine : cdti 150
    Angry help p2279 grrrrrrrr
    help i have a 2006 cdti 150 i have the spanner light on the car has had the inlet replaced 6 months ago egr replaced last week and the boost sensor cleaned. it was fine for 3 days then the spanner light has come on no power under 2k at all hits the limp at 3500 helppppppppp im supposed to be going away friday in the car please anyone lol
    Jul 2012
    sheffield
    Vehicle : vectra
    Trim : sri
    Engine : cdti 150
    oh and it doesnt have a dpf
    Jan 2012
    Gloucestershire
    P2279 is an air intake fault of sorts. Possibilities, working your way down the air intake path (not sure these would all give the P2279 fault though):-
    1) Clogged air filter
    2) Faulty MAF sensor
    3) Hose leak from MAF to turbo
    4) Turbo problems - including vacuum hoses
    5) Hose leak from turbo to intercooler
    6) Leaking intercooler
    7) Hose leak from intercooler to throttle housing
    8) Throttle housing fault
    9) EGR fault
    10) Inlet manifold problem, icluding swirls
    11) Boost sensor fault
    I would go with the simple stuff first. As you have a new EGR and manifold, then start with hose inspection.
    The vacuum hoses (2 thin hoses from the near right of the engine bay as you lead in - on a 120ps, not sure about 150) are common failure points. They tend to perish and eventually split at the elbow joints. You may not see the splits without flexing the elbows.
    Then check for splits in the intake hoses - the ones either side of the intercooler are prone as is the intercooler itself, but you would usually hear a whistling.
    If no luck, the MAF sensor attached to the airbox is the same for a 120 and 150, so if you know someone with a good one, it's a 2 minute swap out.
    Good luck!
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 139000
    Jul 2012
    sheffield
    Vehicle : vectra
    Trim : sri
    Engine : cdti 150
    Forgot to say I've changed them aswell
  1. H.I.D`s Grrrrrrrr
    By Tam80 in forum Electrical & ICE (including SatNav)
    Last Post: 1st March 2011, 18:58
  2. P2279
    By rob123 in forum Engine & Drivetrain
    Last Post: 26th June 2010, 09:49
  3. Poxy HIDs !!!! Grrrrrrrr
    By Matty777 in forum Electrical & ICE (including SatNav)
    Last Post: 6th May 2010, 21:03
  4. Grrrrrrrr - Police Mechanics - Grrrrrrrr
    By Ian-Highlander in forum Vectra C / Signum Car Chat
    Last Post: 10th July 2008, 19:23
  5. Grrrrrrrr - RANT - Grrrrrrrrr
    By Angel Boy in forum General Chat
    Last Post: 6th April 2006, 23:46
p2279 maf
