Results 1 to 10 of 11
Thread: Estate reverse light wire - ID for park sensors
    Apr 2011
    Buckingham
    Default Estate reverse light wire - ID for park sensors
    Hi. Just fitted CISBO sensors but cannot ID reverse light wire in left side boot (fuse area) of estate car (2007 Life). I checked all the old posts but the links are dead so can't find a pic or precise description. Any help or pic would be so appreciated as I really want to see if they work! Thanks
    Jan 2012
    Milton keynes
    Trim : M Sport and Design
    Mileage : 38100
    http://www.vectra-c.com/forum/showth...nsor-positions
    The wiring should be the same...
    If that fails... You could just turn the key, put it in gear so the reverse light is on, and then just stick the wire in the block, moving down and seeing if you get a beep from one of them, then take it out of gear, see if it's the right one. Thats what I did with my front ones, to find the brake light.
    Engine : 1.9 CDTi
    Pretty sure its a Black wire with a yellow trace.
    Regular Member Gubmint Agent's Avatar
    Feb 2011
    Feels a lot like Kathmandu.
    Trim : Sri
    Engine : 2.2 Direct
    Think it's white with black stripe on the hatchback, if that's any use?
    Apr 2011
    Buckingham
    Yep. Took your advice and stuffed the wire in the holes in the block and bingo they work! Thanks for that. Any ideas what the crimp on connectors are called for the wire to secure in the pin in the block. I live miles from a Maplin so will need to try eBay. Thanks a lot.
    Jan 2012
    Milton keynes
    Mileage : 38100
    I just used electrical tape and a cable tied it to the reverse wire to keep it in the hole, I never removed the reverse wire to crimp it.
    Apr 2011
    Buckingham
    There's not actually any wire in the hole in the block! So I need something to keep it in there.
    Jan 2012
    Milton keynes
    Mileage : 38100
    Quote Originally Posted by isdmac View Post
    So it isnt in there with the reverse light wire?
    Apr 2011
    Buckingham
    No. I looked at the picture for the hatch (as above - link) and used PICTURE 1: blue block socket 1 / pin 1. But my car is the estate and there is no wire in that position but it functions as it should - reverse sensor activate with reverse gear selection. I hope it will be ok. No warning lights on the dash etc. What do you rekon?
    Jan 2012
    Milton keynes
    Mileage : 38100
    If it works when just the reverse light comes on, then I guess it would be fine. I guess you maybe dont have the bulb fail relay for the reverse lights? I may be wrong.
    Best mod I ever did to my car...
  1. reverse + wire
    Last Post: 8th December 2012, 13:56
  2. Rear Air Vents/Reverse Light Wire
    By DeeBe in forum Vectra C / Signum Car Chat
    Last Post: 23rd July 2011, 14:15
  3. Parking sensor - which wire is reverse?
    By andyfeeny in forum Electrical & ICE (including SatNav)
    Last Post: 27th July 2010, 22:41
  4. fitting reverse sensors to an estate
    By solorider in forum Vectra C / Signum Car Chat
    Last Post: 1st January 2009, 23:00
  5. reverse sensors, light out, and blipping
    By Mikeymate in forum Vectra C / Signum Car Chat
    Last Post: 8th October 2008, 11:58
07 vectra c reverse light power
which is reversing light wire vauxhall insignia
vectra c estate reverse wire
reverse light on vauxhall vectra c estate
vauxhall insignia doesnt activate reversing light
Vauxhall insignia reverse wire in front
