Results 1 to 2 of 2
Thread: Vectra 2.0 DTi difficult to start when warm
    Jul 2012
    Worcester
    Default Vectra 2.0 DTi difficult to start when warm
    Hi, new to the forum, and have seen many problems relating to vectra starting difficulties. Have done many of the things suggested regarding starting problems when cold and wondered if there are any further ideas out there but for when the car amd he conditions are "warm".
    Crux is that when I went away for a week recently the car turned over first time, but if I have left it overnight or for 2 days it will turn over at the second time of asking, and if I have been driving it already that day it will take 3-4 attempts to start - to the point that it has completely drained the battery today. Also the warmer the weather, the more difficult it is to start!
    I have replaced: Leak off Pipes, Glow Plugs, Fuel Filter. Had the dealer look at it who said that it was the fuel pump (but as it was connected to he FCU would cost £1800 for the part alone!). I am considering going down the route of Temp Sensor, but at the moment am hesitant as everything else has failed so far.
    Any thoughts? Thanks in advance.
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    For the 2.0 DTi, there has been an ECU software update available from the dealers, that alters the glowplug heating timing.
    I'd contact VX and see if the update has been done on your car if I were you
    Edit>>> Taken from another thread, as below
    Quote Originally Posted by bigmac View Post
    Field Remedy: 1579
    Subject:Engine - Bad cold start behaviour Models:Engines:Option:Vectra-C 2002...2003Y20DTHNoneComplaint:Bad cold start behaviour especially between +5 and +9°C coolant temperature.Cause:Problem caused by Software deviation.Production:Production implementation pending, details will be communicated upon availability.
    Remedy:
    In case of customer complaint reprogram with new software (decrease of cold start injection amount and modified preheat phase timing).Available with TIS-CD 40, April 2003.Functional Group:J - Engine Complaint Group:13 - No/Poor Function Trouble Code:None
  1. Vectra wont start when warm!
    By haye5 in forum Engine & Drivetrain
    Last Post: 14th November 2017, 17:32
  2. Vectra 2.0 Dti Difficult To Start
    By dan9895 in forum Engine & Drivetrain
    Last Post: 18th April 2012, 16:30
  3. CDTI 120 difficult to start
    By matt_harw in forum Engine & Drivetrain
    Last Post: 14th November 2011, 21:48
  4. sri 120cdti difficult to start in morning
    By Turbomanrony in forum Engine & Drivetrain
    Last Post: 1st August 2011, 05:27
  5. difficult to start in the morning
    By patrick1062 in forum Engine & Drivetrain
    Last Post: 18th July 2009, 20:32
