Thread: 1.9cdti (120) Squeal under load
    Regular Member 2wheelstu's Avatar
    Feb 2012
    Warwickshire
    Default 1.9cdti (120) Squeal under load
    I'm hoping someone out there may be able to shed some light on a problem that i am having. When i put the car under load, for example third gear at 1400 if i put my foot down i get a loud squealing / whining noise. This happens in any gear trying to pick up from low revs, I sometimes get the noise when accelerating hard up to 3500rpm-4000rpm although i rarely do this.
    Stuart
    East Ayrshire
    Trim : SRI XP1
    Slipping aux belt? The part is about a tenner, unsure of the work involved on a 120bhp but the 150 can be done in about half an hour - hour
    Jan 2012
    Silverstone village
    Quote Originally Posted by stevie16v View Post
    Regular Member C-Owner's Avatar
    May 2011
    South London
    Just a heads up on this problem.
    You are not "loading" the engine but "labouring" it in that low rev range, the tensioner pulley is jumping around and cant cope with the strain.
    Also/due to >>>>
    Make sure the engine under panel is still fitted to the car.
    Its a plastic under tray covering the bottom of the engine and the aux belt run.
    if this is not fitted replacing the tensioner and aux belt is pointless as it will squeal due to the road dirt grime as its unprotected.
    You can buy a spray can of silicone belt lube to keep things quiet for a few weeks depending on road conditions.
    Feb 2012
    Warwickshire
    Cheers guys, I'll get on it this weekend.
  1. Part load misfire 1.9CDTi 150
    By Python in forum Engine & Drivetrain
    Last Post: 12th November 2012, 17:40
  2. loud squeal around 2k rpm
    By skene in forum Engine & Drivetrain
    Last Post: 21st August 2012, 13:19
  3. Got Squeal ??
    By wardy23 in forum Suspension, Wheels & Brakes
    Last Post: 19th March 2012, 22:42
  4. Brake Squeal
    By yoclick in forum Suspension, Wheels & Brakes
    Last Post: 17th August 2009, 19:32
  5. squeal
    By Guyver1 in forum Vectra C / Signum Car Chat
    Last Post: 1st December 2007, 20:57
vectra c squeaking noise under load
vectra c 1.9 belt squeal when under load
vectra c 1.9 belt noise under load
noisy squealing vectra 1.9cdti under load
