Thread: key 2 not working.
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Trim : Smart and Bad!
    Mileage : 105000
    Default key 2 not working.
    as above. the key 2 not working. i replaced battery 2 times. thought i best check the fault codes and it comes up with no communication. as if it need programming to work together again. the immobilator works as usual. my first key alays works without a problem.
    i changed the battery quickly to keep memory or something intact and locking/unlocking worked afterwards til my wife went out and tried to lock and it failed.
    so how do i reprogram the key to work with the car?? looked in index of how 2s and could not find one there???
    Mileage : 000
    Sounds like it is a tech 2 job. But try putting the key in ignition but not starting, just lights on. Then press either button on key. If door buttons pop up and down then you should be ok . If not tech 2 job.
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Mileage : 105000
    I got tech2 and others. So what should i do first?
    Quote Originally Posted by ed taylor View Post
    There is another method mentioned in the handbook. The PDF copy is on my other computer though, so can't copy/paste from it.
    Something like unlocking door with key, then inserting into ignition without having to press the buttons.
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Mileage : 105000
    Wife came back, i finally have key 2 and car, went to test it, working now. Key in ingition then press button it now working fully. Cos it threw a code. So had to get it sorted.
    Thanks for ur help :-)
    There is another method mentioned in the handbook. .
    Here it is:-
    Radio remote control synchronisation
    After a battery change, unlock door with key in lock. Inserting the key into the lock synchronises the radio remote control.
  1. radio working, not working, working again
    By J P S in forum Electrical & ICE (including SatNav)
    Last Post: 22nd February 2012, 00:59
  2. Replies: 4
    Last Post: 11th November 2011, 12:05
  3. Replies: 0
    Last Post: 10th November 2011, 22:58
  4. Working out MPG
    By justin32 in forum Vectra C / Signum Car Chat
    Last Post: 14th October 2011, 10:51
