Thread: Cd70 code index?
    Jul 2010
    Sheffield
    Default Cd70 code index?
    Hi,
    I have a hatchback, petrol (Z18XER) facelift vectra which I recently upgraded to cd70 + CID, everything works fine and suprisingly had the check control and Board computer already enabled, now the niggle is that avg consumption seems fine - around 38 mpg, but the range seems higher than I'd physically expect to get out of a full tank.
    Now in the test mode it says the code index is 11. Is that right for my car or does the range figure in other factory fit BC seem to be higher than physically expected.
    Any help would be much appreciated.
    Wirral, UK
    Vehicle : Mokka
    Trim : SE - Orange Rock 's !!
    Engine : 1.7CDTi
    Code 11 is right, and yes I have more range with a CID than i do with a GID. Swapping between them one day I lost 60 miles fuel range!!
    In my experience, the lower the fuel level goes, the faster the fuel guage goes down, it's as if the tank level sender is not quite linear.
    Regular Member rockonoli1's Avatar
    Telford
    We have just had a 06 plate Vectra traded in at work that has the colour display but mine has the monochrome, how easy is it to swap the display? Sorry for the thread hijack. Cheers Stu
    Jul 2010
    Sheffield
    Quote Originally Posted by TonyP2020 View Post
    Thanks for the reply Tony, you've put my mind at ease that it is set right anyhow. It is strange about the range, I never run the tank below half way, so as you say about the lineararity that it will become more 'realistic' as the tank volume becomes less and less.
    Cheers,
    Full Member Robsey's Avatar
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    Quote Originally Posted by rockonoli1 View Post
    It depends -
    You could swap your CD70 and GID for the CD70 and CID as complete units.
    If you only swap the displays, then you need to mess about divorcing and pairing the displays as required.
    If you do put your own CD70 and GID into the other car I recommend 2 things.
    a) Get the vehicle security code from the car with the CID, in case you wish to do any security programming at a later date.
    b) Return the favour, by writing your security code on your old CD70's chassis or leave a note with the vehicles audio manual, if it still has one.
    Basic variance config and code index programming will not require the security code, but
    if you later wish to add a telephone portal UHP4, then you would need to divorced the infotainment system, and then pair everything up again including the UHP4.
    Adding or removing any single infotainment component would require programming. (Tech 2, Tech 3, Opcom Vauxcom).
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    Quote Originally Posted by markymarky View Post
    Cheers,
    I cannot think of any fuel gauge that reads in a true linear fashion.
    It is possible to "trim" the fuel consumption figures via a bit of "special function" programming on the ECM (Engine control module).
    You can do this by increasing or reducing the consumption figures by a % value.
  1. BC Code Index
    By hodge725 in forum Electrical & ICE (including SatNav)
    Last Post: 2nd December 2012, 16:54
  2. Code index - can you tell me yours - instructions included :)
    Last Post: 2nd July 2012, 21:17
  3. cd70 code
    By davidlewis24 in forum Vectra C / Signum Car Chat
    Last Post: 25th April 2011, 11:49
  4. BID Index Code Help
    By duncmill in forum Electrical & ICE (including SatNav)
    Last Post: 27th February 2011, 20:55
vectra c code index cd70
https:www.vectra-c.comforumshowthread.php168034-Cd70-code-index
vectra cd70 enabling on board computer
code index cd70 vectra c
why do my cid on cd70 navi saying i more fuel in then there is.
cd70 code index
cd70 navi index programing
opel vectra c code index
