Thread: Steering wheel not straight, but car drives straight?
    Jul 2012
    Essex
    Default Steering wheel not straight, but car drives straight?
    Hi all,
    I hope I am posting in the correct section (as I am new)..
    I have recently purchased a Vectra C SXI CDTI.. I am really loving the car, however it has a few niggles that I would like to fix..
    In this section I would like some help with the steering wheel, the car drives straight, with no pulling or wobbles, however the wheel is not straight whilst moving straight? (if that makes sense?)
    Hope you can offer some advice..
    Danny
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Need to check the track rods are adjusted evenly. You'll probably find some lazy mechanic had only adjusted tracking on one wheel.
    Jul 2012
    Essex
    Ahhh ok, apologise for my lack of knowledge... does that mean I should book it in to get the tracking done?
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    Probably best mate yes.
    a full geometry check is best tho.
    Visit align my car.co.uk to find nearest place with hunter machine
    Jul 2012
    Essex
    Ahh excellent just looked on the site, and there is a garage 5 minutes round the corner!
    Thanks again..!
    You have two choices
    The expensive four wheel alignment (between £60 and £100), typically using Hunters equipment
    This is best carried out with new tyres and during the first few weeks of ownership
    It is also essential to make sure the suspension and steering is in good condition, even play is unacceptable
    The cheaper front wheel alignment only (between free and £30), typically using SuperTracker
    This is best carried out after the above, in order to check the alignment has not changed dramatically
    As above, a cheats method to obtain wheel alignment is to adjust one track rod only
    This results in the steering wheel becoming off-centre
    Some owners will accept this, others won't
    Equally, it could also be a sign that the other track rod has seized, and needs replacing
    Personally, get three quotes for Front Wheel Alignment
    They should advise it is free to check, but if an adjustment is required there is a fee (amount)
    I suspect they will find one track rod is seized
    Initially they should heat it, but this doesn't always work, and the only solution is to replace
    I would recommend if this is the outcome that both track rods are replaced
    They aren't too expensive, and the garage should be able to fit them as well
    However, as with all VX parts, buy them at the dealership yourself as all too often the wrong parts arrive!
    Nov 2010
    East Midlands
    Trim : design
    Just have your front wheels aligned - I would free the adjusting nuts off and retighten them before I go - and stress that you want the steering wheel in the straight ahead position - most experienced mechanics will know this and look at you gone out but if you get the YTS lad...... and if it isn't right you have pre warned them that you will be back.
    Jul 2012
    Essex
    Appreciate comments above. Very helpful..!
    I am off for 2 weeks soon, so will get down the garage, and also get my tools out to have a go at a few jobs myself!
    Will no doubt be back on here for further questions!
    Chelmsford
    Quote Originally Posted by Critch View Post
    That REALLY gets on my nerves!
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    Quote Originally Posted by DNS View Post
    Not the only one mate.
    most bad traits that give the trade a bad name pi$$ me off.
  1. Steering wheel not straight
    By BooDaChris in forum Vectra C / Signum Car Chat
    Last Post: 8th February 2013, 23:24
  2. steering wheel to one side,while driving straight
    By RRadek in forum Vectra C / Signum Troubleshooting
    Last Post: 3rd September 2011, 10:50
  3. Steering wheel still not looking straight after tracking
    By ishaqmir in forum Suspension, Wheels & Brakes
    Last Post: 31st March 2011, 13:55
  4. Steering wheel points left when going straight
    By cheekylemon in forum Vectra C / Signum Car Chat
    Last Post: 22nd November 2008, 21:27
