Thread: No power in low revs vecrta 1.9 cdti sri
    May 2012
    cheshire
    Default No power in low revs vecrta 1.9 cdti sri
    Having trouble with power in low revs, but as soon as revs hit 2k rpm it picks up.
    Ive reacently had fitted
    New egr valve
    2 new injectors
    Injector wire loom
    Battery
    Any common fault on these?
    Many thanks
    South Central England
    17 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    A search first would have shown swirl valves and vacuum line leaks too.
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Quote Originally Posted by nutron View Post
    Swirls. If the bar is off, search for my thread "CDTi 150 Swirl Bar"
    Mine's like a different car since the fix
    Regular Member Adam8220's Avatar
    Apr 2011
    Ripley, Derbyshire
    if that s all ok check the intercooler and boost pipes for leaks. seem to be common too.
    those symptoms on mine were down to sticky egr valve though. check egr actuation with tech 2 and wiring to egr from ecu.
    clean off boost pressure sensor that usually helps
    May 2012
    chelmsford
  1. 1.9 cdti 120 difficult to start and low power under 1500 revs
    By johninthetoon in forum Vectra C / Signum Car Chat
    Last Post: 29th September 2010, 07:46
  2. Signum 120 CDTi black smoke and loss of power @ low revs!!!!
    By siw8158 in forum Engine & Drivetrain
    Last Post: 29th July 2010, 17:08
  3. no power at low revs cdti
    By brownlow39 in forum Engine & Drivetrain
    Last Post: 22nd May 2010, 19:39
  4. 1.9 cdti power loss at low revs
    By topdogs in forum Engine & Drivetrain
    Last Post: 27th January 2008, 03:56
  5. vecrta 2.2 needs more power
    By beefycol in forum Petrol Engine related
    Last Post: 28th November 2007, 21:30
vectra c 1.9cdti loss of power at low revs
