Thread: Z30DT Timing Belt Questions
    Regular Member rmg1's Avatar
    Limavady, N.I
    Vehicle : Vectra C Sri V6 CDTi
    Engine : 3.0 V6 CDTi Z30DT
    Mileage : 121000
    Default Z30DT Timing Belt Questions
    Can anybody confirm if 93196790 is the correct part number for a z30dt 3.0 V6 CDTi timing belt kit and do you need to change the water pump when you change the belt? I only ask as I've been getting different info from different dealers. I was also told by 2 other VX specialists that I only needed the belt and tensioner.
    Don't have the part number, but correct only the cambelt kit is required (belt and tensioner)
    Recommended to change the Auxiliary belt at the same time
    Check the tensioner, they also last about 100K miles; some people recommend replacing that as well
    South East - Assistant RO jaqubek's Avatar
    Sep 2011
    london
    10 Post(s)
    Vehicle : Vectra C Estate
    Engine : v6 3.0cdti
    I would like to know that too. I`m not 100% sure but I think I read somewhere that only need belt and tensioner. Need someone to confirm
    Regular Member Johnny-B's Avatar
    May 2012
    Rīga
    Trim : Elegance
    Engine : Z30DT
    Check possiability for aftermarket belt kit- I got CONTINENTAL kit for above 100 pounds!, OE tensioner was abowe 140 Pounds only!
    Limavady, N.I
    Mileage : 121000
    I have checked with motor factors and the are looking £250-300 for the kit, I got a price of £60 for the belt and £120 for the tensioner, but I've seen a VX kit for £150 if the above part number is correct.
    wirral
    56 Post(s)
    Vehicle : Mk1 renault scenic... I know I know but it drives
    Trim : Basic
    Engine : 1.6 16v
    Don't need to change water pump as its run internally from gears
    I got my belt kit including tensioner an 2 idlers for y 30 from autovaux for £162
  1. anyway to do the timing belt without timing tool
    Last Post: 15th December 2012, 18:47
  2. Timing belt
    By shb1988 in forum Vectra C / Signum Car Chat
    Last Post: 9th August 2012, 19:51
  3. Timing Belt... OMG!!
    By tony-1977 in forum Vectra C / Signum Car Chat
    Last Post: 14th August 2011, 18:27
  4. timing belt?
    By leonvectrac in forum Engine & Drivetrain
    Last Post: 28th April 2011, 19:02
  5. Timing Belt
    By juggernaut in forum Vectra C / Signum Car Chat
    Last Post: 11th June 2010, 20:43
vectra z30dt timing belt change
timing belt change on z30dt
z30dt timing
