Thread: Can Someone Identify This Pipe?
    Regular Member john506's Avatar
    Mar 2011
    Wirral
    Default Can Someone Identify This Pipe?
    Been having lumpy cold start ups and a smell of diesel when I put the interior fan on.
    Do you think this is the culprit?
    Could anyone identify what this hose is for?
    It is at the front right hand side of the engine
    South east
    .....and which engine is that?
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Looks like a CDTi 150 engine. The pipe arrowed is a coolant pipe I think.
    As for lumpy cold satrts and smell of diesel, I'd be checking the swirl bar, may have fallen off
    Mar 2011
    Wirral
    Sorry yes it is the 1.9cdti 150, there is all black oily crud around the pipe like it's been leaking.
    Checked the swirl bar and still seems to be attached
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Is there any oily deposits around the swirl pots? Could be one of the valves leaking a little. Does the swirl bar move when revved? (will need a friend to check while you rev it).
    Re the pipe in your pic, Mine looks identical to yours, and there's no diesel smell or lumpy cold starts.
    May be worth cleaning the EGR and boost sensor too, and checking the vac pipes for splits. May help with the cold starts.
    Mar 2011
    Wirral
    no carbon around the swirl bar. Just had another look, the pipe is the one that goes from the engine block to th oil seperator. I blanked off my EGR hoping it would sort the lumpy start ups to no success.
    Got another black pipe to the right of the engine with black oil all over it and it has sprayed it all over the engine block.
    Gonna take them all off some time next week and give em a check over and a clean and put them back on with jubilee clips nice and tight!
    Thanks for your time
    Regular Member 4ndy's Avatar
    Oct 2010
    Glasgow
    That looks like the coolant pipe from the thermostat to me. There shouldn't be any oil there. Is there any trace of oil in your expansion tank?
  1. Brake servo pipe Help (Plastic Pipe)
    By Mark2.2 in forum Suspension, Wheels & Brakes
    Last Post: 17th April 2014, 15:41
  2. Identify this pipe please
    By Kaput in forum Engine & Drivetrain
    Last Post: 16th July 2012, 11:02
  3. Identify the box....
    By Danger_MouseUK in forum Diesel Engine related
    Last Post: 24th January 2012, 09:43
  4. identify this pipe?
    By paul.sessions in forum Engine & Drivetrain
    Last Post: 9th December 2011, 18:27
  5. can anyone identify...........
    By Teamtom in forum Styling
    Last Post: 16th April 2009, 00:16
