Results 1 to 10 of 11
Thread: airbag fault
    TELFORD
    Default airbag fault
    hi guys can someone help me with the above i've got the airbag light on dash i have run diagnostic comes up with low resistance on stage 1 passenger airbag squib any ideas as to what part i need to look at as wiring is all sercured?
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Not sure on that one, but I'm sure someone will be along who can help more.
    However, have you tried clearing the fault to see if it returns?
    TELFORD
    yes just comes back up
    Aug 2010
    Derbyshire
    Have you tried disconnecting the battery to see if that clears it? just something simple to try.
    Mick
    TELFORD
    yes done that still no difference
    Regular Member Mr Owens's Avatar
    Jun 2012
    Wickford
    Trim : Sri
    Engine : 2.2 direct
    What machine have you used to read the codes ?
    Things like the snap on solus will read the actual resistance in all the airbags and pretensioners.
    I would have thought that would be the actual passenger airbag as they are usually 2 stage bags
    TELFORD
    opcom!!!
    Full Member Caveman_nige's Avatar
    Jun 2009
    South Coast
    Vehicle : Vectra and a Signum
    Engine : Z18XE,Z19DTH,Z20NET
    remove the glovebox and check the connections on the airbag, its easy to access with the glovebox out.
    Regular Member any-mgzt's Avatar
    cheshire
    Trim : basic
    Engine : Z19DT
    The wiring for the SQUIB airbag is under the seat
    Admin plasma's Avatar
    On the Forum
    265 Post(s)
    Engine : 150
    Mileage : 74000
    that would be the sideair bag and pretensioner under the seat, the squib one is the passenger dash..
    Plasma's Tech2 services are now partially open and able to provide services
    Come Join our new forum Insignia Owners.com for all your Insignia chat and needs
  1. what would cause all these airbag fault codes?
    By krazylegz in forum Electrical & ICE (including SatNav)
    Last Post: 25th April 2012, 18:36
  2. Airbag ECU fault codes ??????? ?
    Last Post: 12th September 2011, 20:39
  3. Can someone please help. AIRBAG FAULT
    By Bigg943 in forum Electrical & ICE (including SatNav)
    Last Post: 14th July 2011, 22:32
  4. Airbag ECU fault
    Last Post: 2nd February 2011, 23:22
  5. B1000 airbag fault - what would you do?
    By James24 in forum Electrical & ICE (including SatNav)
    Last Post: 24th January 2011, 12:51
