Will 80 watt bulbs be ok for main beam? Just read on packet that id need to check the wirering is heavy enough![]()
I had 100 watts on my vectra bud and they were ok
Cheers. No problem just thought ad cheak before i opened them.
No worries mate
Several things spring to mind.
Is the existing wiring man enough for the job?
Is the existing relay man enough for the job?
Will the extra heat generated melt the silver reflectors, or the plastic lenses?
If you need to increase the wattage of your main beam, is your eyesight ok? Standard bulbs in the main beams are usually bright enough without having to upgrade. Dipped beams however.....
The wiring, headlamps etc will all cope fine
But they are not road legal
Would the higher wattage lamps effect the lampcheck????
No they work fine
