Thread: gear stick
    Regular Member SarahP's Avatar
    Nov 2011
    Buckinghamshire
    Default gear stick
    okay, does one know why my gear stick top pops off.. just the top bit that has the gear numbers etc on it, can be driving along then 'pop' out the blue the top has popped off into passenger side and I have to change gear without it until i can stop to push it back on!!
    Anyone elses ever done this?
    Mar 2011
    Bedworth
    Vehicle : Vauxhall Signum
    Trim : Elegance
    Engine : 1.9 CDTi 120PS
    Year : 06
    Mileage : 115000
    I had the exact same thing happen on my 2006 Vectra, and on my current 2006 Signum - real PITA when you're trying to make rapid progress up a motorway slip road!
    A bit of superglue worked in the Vectra. But in the Signum I've noticed that the rubber/plastic lining of the hole in the top part is mostly missing, which means the 'splines' on the stick have nothing to seat against, and the top pops off really easily.
    I imagine some epoxy resin might do a better job in my case, but it might make the knob very difficult to remove in the future...
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    As said above. Bit of glue or liquid nails, pop it on, and give it a good whack into place
    Mine was the same, sorted out and no further problems
    Dec 2011
    Seaham
    Yes, they are just a push fit, and you have to buy the complete stick to get a new knob from Vauxhall. They can be stuck back on with glue or better still some epoxy like araldite.
    Or, get an aftermarket knob like a Richbrook.
  1. Gear stick
    By Puffalo bill in forum Bodywork & Interior
    Last Post: 4th January 2012, 18:34
  2. Reverse gear - weak spring on gear stick
    By Dal5band in forum Bodywork & Interior
    Last Post: 20th December 2011, 13:18
  3. gear stick
    By reeseandellie in forum Suspension, Wheels & Brakes
    Last Post: 11th April 2011, 16:32
  4. Vec C 52 plate 2.2 Dti Gear Stick Jumps out of 1st gear on take off
    By ukwanderer01 in forum Engine & Drivetrain
    Last Post: 5th July 2009, 21:43
