Thread: Heater fan problems
    Jun 2012
    Woodley, Berkshire
    Default Heater fan problems
    Hi all, over the weekend I noticed that the heater/blower fan is not working on setting 1,2 & 3 only on setting 4? Any idea's?
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Resistor pack on the bottom of the blower motor housing.
    Remove the glove box and you'll see the loom going in to it.
    Will need repalcing, but clean the scuttle drain in front of the pollen filter to keep the water out, as that's what blows it
    Edit >> Look here: http://www.vectra-c.com/forum/showth...otor+and+resis
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 138000
    as above you need a resistor pack
    http://www.vectra-c.com/forum/showth...l+scuttle+tray
    Water leaking in car fix -* VIDEO *-
    click here
    http://www.youtube.com/watch?v=XxOxr...1&feature=plcp
    Regular Member carperjake's Avatar
    Scunthorpe
    Trim : Elegance CDTi 120
    Engine : 1.9
    New heat fuse from ebay, http://www.ebay.co.uk/itm/VECTRA-C-S...item2a1ff8f1e6
    £9.44 and next day delivery. Loads of info on here on what you need to do but the seller above also puts in a full info pack with the fuse. You may well also be getting wet carpets in the passenger footwell, check the scuttle tray and the heater inlet. There's loads on that here too.
    Jun 2012
    Woodley, Berkshire
    Great, Cheers lads, I've ordered a replacement one from the ebay link(thanks carpetjack) hopefully fit it the weekend. This is a cracking website, cheers all
    Jun 2012
    Woodley, Berkshire
    Hi all, just thought I would et you know that I brought the resistor(thanks carperjack) The instructions that came with it were spot on, removed glovebox,heating pipe, resistor pack, cut off old one fitted new old, tested....purfect!!! refiited it all back and cleaned/washed out the drain hole outlet and refitted, a bargian price, top instructions and a 20 min job. Fantastic!!!!!
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Mileage : 138000
    Quote Originally Posted by woodley Vectraman View Post
    thats what we like to here
    this site has a lot of knowledgeable people on here and its nice to see
    that you have got your car sorted out.
    again thanks for your reply
  1. Heater Problems, And then some.
    By Deathtopia in forum Vectra C / Signum Troubleshooting
    Last Post: 9th February 2011, 09:58
  2. heater problems
    By pete w in forum Bodywork & Interior
    Last Post: 12th December 2010, 21:28
  3. heater problems!!
    By dazza2393 in forum Electrical & ICE (including SatNav)
    Last Post: 11th July 2010, 08:32
  4. heater problems
    By blackcountryroy in forum Bodywork & Interior
    Last Post: 16th January 2010, 19:38
  5. Heater Problems ???
    By suj786 in forum Electrical & ICE (including SatNav)
    Last Post: 1st October 2005, 01:10
