Thread: Steering Help
    Regular Member Voxer's Avatar
    Ayrshire, Scotland
    Default Steering Help
    Thinking Caps on guys I've got a bit of a steering problem.
    A symbol of a steering wheel and an exclamation mark has appeared on my dash and at the same time so has my traction control light, my steering doesn't feel any different but i'm getting a little worried.
    It's happened 3 or 4 times, the first 3 happend at times when i've started moving and had a little wheelspin, the tc light flashes as normal then about a mile down the road both steering and traction lights came on.
    The fourth happened today when I was circling a car park looking for a space, I wasn't down more than 5mph and after about 2-3 min both lights came on.
    any ideas what's wrong.
    barnsley
    when you get a fault with ps ,its all link up with the traction control ,both of my light came on and did not go off ,it was my ps pump,got a second hand one 150 from vaux bits.
    Feb 2007
    Barnsley
    There's also the possibility that there's a sensor fault; there's a level sensor in the PS res. Or there's an occasional problem with condensation in the connectors, which can cause a short - and put the PS indicator on.
    Oct 2006
    Waterloo, Liverpool
    Trim : SRI NAV XP
    Engine : 1.9 CDTI 150
    Mileage : 72K
    I had the steering wheel graphic up on my old Active 1.8, and had the power steering pump replaced under warranty. Given the TC light as well, could be a sensor, I suppose.
    Ayrshire, Scotland
    Cheers guys, got it fixed, it was needing topped up.
    panicked before thinking.
    Regular Member Gazza90000's Avatar
    Newcastle upon Toon
    Good ... BTW I do like those Alloys matey..Yum
  1. Power steering pump noise? but no steering problems
    By bennettboy in forum Engine & Drivetrain
    Last Post: 2nd November 2012, 21:33
  2. Steering wheel light & loss of power steering
    By the_wave_rider in forum Vectra C / Signum Car Chat
    Last Post: 3rd August 2012, 14:09
  3. Steering wheel warning light , no power steering!
    By Domchapp in forum Vectra C / Signum Car Chat
    Last Post: 23rd July 2012, 22:11
  4. Replies: 6
    Last Post: 13th March 2011, 10:47
  5. Steering wheel sign...power steering cut out..what can it be
    By vec3.2 in forum Engine & Drivetrain
    Last Post: 16th April 2009, 21:07
