Results 1 to 10 of 17
Thread: :( So Fed Up - Gearbox spat out the drain plug!!!!
    Middlesex
    Trim : SRI
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 100k
    Default :( So Fed Up - Gearbox spat out the drain plug!!!!
    Got home and red fluid dripping out of the gearbox.. Looked and the gearbox drain plug was half out as if someone had undone it!!!!
    tried to do it back up and it wouldnt even go in. Undid it and took it out and all the thread has been scripped..
    Un-believable! I dont know what to say now. There is absolutly no reason this should have happened. It must have been a weak thread or something where it was overtightened from when I had to chisel it off..
    Gutted.. and stuck!
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Gutted mate.
    You can get temporary sump plugs that have like wings that hook on the inside an you tighten down.
    May do trick so you can drive somewhere an get a helicoil put in
    Middlesex
    Trim : SRI
    Mileage : 100k
    Quote Originally Posted by Critch View Post
    Gutted mate.
    Hmm - thats an idea.
    Also thinking - It seemed to leak a little anyway since having to chisel the old plug off where is was so tight.. It marked the face that mates with the plug to asume that is where it leaked from..
    Thinking that a Helicoil will still leak?? what do you think?
    Actually thinking why not just get it welded up! lol... Dont really need it TBH and if I ever do ill just pop the drive shaft out?
    I dunno.. Really need a fast fix... Dont care if I lose the drain plug, just as long as the dam thing doesnt leak!!
    Jun 2011
    wolverhampton
    Lots of bigger independents will have a sump plug repair kit and bigger plugs so I wouldn't stress tbh just do a bit of research
    Middlesex
    Trim : SRI
    Mileage : 100k
    Quote Originally Posted by sriandy View Post
    Yeah I know .
    I dont like it when things break on me for no reason.. Ive worked on cars for years and it REALLY annoys me!!
    Laser do a repair kit.
    Its a M18 1.5 plug at the mo so would need to go to M20 1.5.. Like this:
    http://www.lasertools.co.uk/news.aspx?article=526
    What do we think.
    Middlesex
    Trim : SRI
    Mileage : 100k
    Administrator plasma's Avatar
    On the Forum
    357 Post(s)
    Engine : 150
    Mileage : 74000
    <--- is reconsidering his timing belt kit lol...
    Middlesex
    Trim : SRI
    Mileage : 100k
    Quote Originally Posted by plasma View Post
    :O:O:O
    Almost wish this was my fault mate - LOL - at least then it would be explainable. hehe..
    Not my fault this one.. You will be in safe hands.
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    A helicoil then depending on how damaged the face is. File an then maybe use two flat washers with an o ring in between ( one just slightly larger than hole. O ring then larger washer an then screw right should make it deal enough.
    Middlesex
    Trim : SRI
    Mileage : 100k
    Thanks for the tip buddy.
    Ive actually ordered the sump plug repair it from Amazon..
    Like the fact that you get a proper plug too and not a stupid torx bit one..
    Thinking I will try it with the brass crush type that these kits come with - and then if that doesnt work, use a dowty washer (metal with rubber insert) to seal it and see how that goes.
    Appreciate your help tho.. Like the idea of a smaller onto a bigger washer to build it up..
    Just hoping the M20 plug will fit into the slight recess that the drain hole sits in on the gearbox.
  1. Gearbox drain plug leak
    Last Post: 18th June 2012, 18:19
  2. auto gearbox drain plug
    By bert01909 in forum Engine & Drivetrain
    Last Post: 19th September 2011, 18:14
  3. gearbox drain plug
    By collyb in forum Engine & Drivetrain
    Last Post: 3rd May 2011, 13:47
  4. Gearbox oil drain plug
    By big nath in forum Engine & Drivetrain
    Last Post: 15th February 2011, 18:13
  5. gearbox drain plug magnet
    By tugger434 in forum Engine & Drivetrain
    Last Post: 5th March 2010, 14:35
