Thread: Brake Upgrade Problem.
    Regular Member bigboynigs's Avatar
    Oct 2007
    ALDERSHOT
    confused Brake Upgrade Problem.
    I recently bought 314mm discs, calipers etc to do the upgrade on my 2006 1.8 Vectra
    All went well until it came to bleeding them, the brakes were solid and spot on for the first couple of pumps and then after about a minute the peddle went right down to the floor. Bled them again and then it happened again.
    Gave everything a going over and there is no fluid leaking from anywhere????
    Have had to put the old setup back on for now just so I have a car with brakes.......any ideas what could be causing the problem as I have run out of ideas
    Engine : 1.9 CDTi
    I know this is a silly question but you did have the nipples at the top didnt you?
    Oct 2007
    ALDERSHOT
    Quote Originally Posted by lee gsi View Post
    (He He, you said nipples) Yes mate as far as I'm aware, if I've got time I'm going to have another go this Saturday and would like ideas as to what to keep an eye out for........I was scratching my head trying to solve this for a few hours last weekend
    Engine : 1.9 CDTi
    Also make sure the clips that hold the pads in are fitted as the same used to happen on the older Vectra's when they were fitted wrong.
    Oct 2007
    ALDERSHOT
    Cheers mate, gives me something to watch out for. The air was blue and the language was very colourful as it didn't make sense. Mind you if it's done, things like this are checked and it still doesn't work then............. which will lead to and and then finally
  2. Big brake upgrade!?
    By byebyeitsagsi in forum Handling & Braking
    Last Post: 10th May 2009, 20:56
  3. Brake bleed problem? on new upgrade.
    By dv8 in forum Suspension, Wheels & Brakes
    Last Post: 15th September 2008, 16:33
  4. Big brake upgrade
    By Beavis in forum Parts for sale
    Last Post: 3rd May 2008, 18:50
  5. Big Brake Upgrade
    By parapaul in forum Suspension, Wheels & Brakes
    Last Post: 15th March 2007, 23:13
