Thread: Fitting an astra gearstick
    Regular Member dilan's Avatar
    Aug 2009
    dudley, west midlands
    Default Fitting an astra gearstick
    I guys , I have a 1.8 Sri 56 plate and I'm wanting to fit the Astra h gearstick which I have now got courtesy of eBay , I've looked at the how 2 but only has info on fitting vxr gearstick to a six speed ... Mines a 5 speed with lift upper left reverse, I've pulled up the gaitor on the vectra to have a look but I'm not sure on how this is done... Any advice from anyone that has done this would be greatly appreciated.... ...
    Sent from my iPhone using Forum Runner
    gwent
    Hi there is four torques star bolts undo now pop the big ball joint out of the metal arm. Now there's a small ball joint at the bottom twist the gear stick so it pop out when it out just ppull the gear stick out and put the new one in.
    Aug 2009
    Thanks for the reply mate, now without sounding thick, I've looked at it and there are 4 upper torx screws by a ball joint and 4 lower down torx screws on the floor of the tunnel of you like, is it the upper or Lower 4 I need to undo, and does the vectra gearstick pull out of the black frame/cage thing easily and Astra one fit in its place easily.... Cheers mate
    gwent
    yes it's the top ones you undo don't touch the bottom ones ok
    Regular Member coldo's Avatar
    Scotland
    Take pics of you doing each stage bud so you can put together a How to for the rest of us
    Aug 2009
    Thanks for the replies guys.... I will take pictures when I attempt it, it'll be on my next day off probably Friday, .. So to summise..... It's undo the 4 upper torx screws, this should then lift the stick but with a bit of twisting and jiggling, remove the vectra gearstick from the black frame thing I've just undone, fit the Astra gearstick back into the black frame thing, and refit..... I've done a lot of things to my car myself in the past.. E.g hid's.. Leather interior etc , but for some reason this gearstick thing is making me a bit twitchy, ha ha.... Oh well , what's the worst that can happen......(gulp)...
  1. Astra H gearstick
    By michael_linford in forum Styling
    Last Post: 10th January 2013, 20:21
  2. Astra h gearstick
    By RBH in forum Bodywork & Interior
    Last Post: 27th October 2012, 14:39
  3. astra vxr gearstick gaiter fitting
    By mrk in forum Styling
    Last Post: 6th September 2012, 18:46
  4. Is it Astra h or Astra j gearstick that fits vec c
    By jon1.9cdti in forum Bodywork & Interior
    Last Post: 10th May 2012, 07:28
  5. Will an astra H gearstick fit a signum?
    By signum_rob in forum Bodywork & Interior
    Last Post: 4th October 2011, 21:49
astra h bottom ball joint gear stick
how to put gear stick back in astra mk5
