Thread: veccy c 150
    Full Member vmb2722's Avatar
    May 2012
    Blackpool/St Mary's Bay
    9 Post(s)
    Trim : Exclusiv
    Engine : 1.9 CDTi 150
    Default veccy c 150
    anyone know the socket size for the crankshaft bolt? i am away from my car at present else id check
    Middlesex
    Trim : SRI
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 100k
    When you say crank shaft bolt.. Do you mean the pulley bolt that the cam belt actually goes round (the one that you dont remove when doing a cam belt) - or the anti-vibration crank pulley that sits over the top of the crank pulley I have just mentioned that the drive/aux belt goes round that you do remove when doing a cam belt?
    May 2012
    9 Post(s)
    Trim : Exclusiv
    The one you don't remove and can use to turn the engine over
    Middlesex
    Trim : SRI
    Mileage : 100k
    99% sure its a 22mm.... I only did a cam belt last week on a CDTI150 and sure its a 22mm I used to turn the engine over.. I could be wrong from memory - but think its that.
    May 2012
    9 Post(s)
    Trim : Exclusiv
    it was 19m but thankyou anyhow!
  1. Drosser Veccy B old hand Veccy C virgin
    By drosser in forum Introduce yourself.
    Last Post: 27th November 2012, 06:42
  2. Thermostat from a 1999-02 veccy onto a 2003-05 veccy?
    By Drazek in forum Engine & Drivetrain
    Last Post: 9th January 2011, 22:21
  3. Veccy may have to go
    By bigknill in forum Vectra C / Signum Car Chat
    Last Post: 16th April 2010, 22:51
  4. Veccy C to replace Veccy B?
    By gtr1000 in forum Vectra C / Signum Car Chat
    Last Post: 19th June 2008, 08:49
  5. V6 Veccy-B to Oil fired Veccy-C
    By Alpha10 in forum Introduce yourself.
    Last Post: 8th February 2006, 09:22
