Results 1 to 10 of 11
Thread: Wynn carb & intake cleaner for 1.9Cdti 150
    Regular Member amand's Avatar
    Feb 2011
    west London
    Default Wynn carb & intake cleaner for 1.9Cdti 150
    basically i gave this a go today and smoke started coming from the back of the engine and into the cars interior itself. What could be wrong? ive recently blanked egr but i tried to tighten the bolts as much as possible. I sprayed some on the swirl bar and intake the throttle body.
    Regular Member nikroc's Avatar
    Nov 2007
    DERBY
    13 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    I would suggest that if you got smoke coming from the back of the engine then you have a leak somewhere. When you blanked your EGR did u seal it?..or just bolt a blanking plate on..can you see where its leaking from?..
    Wondering lonely as a cloud
    23 Post(s)
    Vehicle : M5
    Trim : Nothing needs adding
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    Quote Originally Posted by amand View Post
    If the engine was hot when you sprayed it then it does produce smoke as for the smoke in the cabin the air intake is in front of the passenger seat near to your smoke so unless you press the recirc button on the AC control panel it will get in.
    Feb 2011
    west London
    unfortunetly it wasnt hot. Im kind of worried because the car runs fine. however I do get this smell on start up inside the cabin. and I didnt seal the blank plate. didn't know i was supposed to
    Nov 2007
    DERBY
    13 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    Tbh mate I dont know if your 'supposed' to seal the blanking plate BUT I woulda thought that when trying to mechanicaly bolt two pieces of metal together your never going to get a true flat /seal without using some kinda sealent.
    Presonaly I'da put a thin bead of silicone sealent between the two surfaces..
    Feb 2011
    west London
    oh ok. Thanks for the tip, i'll give it a go.
    Regular Member Elahi_786's Avatar
    Oct 2010
    Bedford
    I have blanked my EGR with a plate without putting the gasket back in place just the plate and have had no leaks so I doubt it would be the EGR Leaking.
    Slough
    72 Post(s)
    Vehicle : insignia vxr
    Trim : vxr
    Engine : 2.8 turbo
    Year : 61
    Mileage : 38000
    had the egr mapped out off mine the other week and just put the blank plate on , instead off the gasket , all good here .
    the vectra has gone , but not far away so ill still see it form time to time
    Feb 2011
    west London
    hmm strange because thats just what i did. Mapped out and just blanking plate. what could cause the diesel smell on start up in the cabin
    Jun 2011
    wolverhampton
    I'd still seal it to eliminate it tbh
  1. Replies: 1
    Last Post: 15th September 2012, 21:13
  2. carb cleaner
    By beat275 in forum Vectra C / Signum Car Chat
    Last Post: 9th September 2011, 00:18
  3. Carb Cleaner / Inlet Cleaner 150 CDTI
    Last Post: 19th July 2011, 09:50
  4. Replies: 7
    Last Post: 2nd July 2009, 17:51
  5. Anyone used air intake cleaner in the 1.9CDTi?
    By wickedwillie in forum Vectra C / Signum Car Chat
    Last Post: 8th April 2009, 06:45
