Thread: ABS & ESP warning!
    Regular Member Johnny-B's Avatar
    May 2012
    Rīga
    Trim : Elegance
    Engine : Z30DT
    Post ABS & ESP warning!
    Hello guys!
    Again need yours expierence!
    After start to drive faster than 30 km/h ABS & ESP and CDC light turned on!
    In Fryday was wery poverfull rain, so I guess that maybe is some connection get full with watter and makes problem! Maybe You know some weak points for ABS circuit and help with advice?
    Of course tommorow will check wth TECH, but maybe is some problem place knowed!
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Check on diagnostics that all wheels are showing same speed.
    And go from their
    Uf lights in should give you a fault code
    May 2012
    Rīga
    Trim : Elegance
    Engine : Z30DT
    Yeah, interesting that after ignition turn off lamp turns off, but after reaching 30 km/h it goes on again!
    Hope that electric will have aviability to look what is the problem, as at moment i understand that shocks is working in sport mode?
    Regular Member nikroc's Avatar
    Nov 2007
    DERBY
    17 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    Have you though of cleaning the ecu/abs connections in the engine bay?..I had a similar issues. Followed a thread on here,cleaned the electrical connections using..brake cleaner(was all I had at the time and its a solvent at the end of the day). let it evaporate,plugged back together and SORTED.
    Took about ten minutes,including drying time.
    May 2012
    Rīga
    Trim : Elegance
    Engine : Z30DT
    Thanks for advice!
    No, I doesnt do anything yet- I drived from holidays and at home saw warning light :@
    May 2012
    Rīga
    Trim : Elegance
    Engine : Z30DT
    Quote Originally Posted by Johnny-B View Post
    Thanks for advice!
    Today checked with TECH, fault was for front right sensor! checked connection, it was clear, after drive abowe 10 kilometers, at moment ok Hopes that heel hub wount be needed to replace
    May 2006
    scotland
    I had exactly the same fault as you. My thread is on here from about 3 months ago (do a search). It was the front nearside cable which is under the front wing and goes towards the inner wing before it pops up into the engine compartment. The Diagnostic tool diagnosed High Volts on that wheel circuit and the auto electrician diagnosed that the cable was slightly shorting within. Cable replaced for a couple of months now and no more faults. Good Luck.
    May 2012
    Rīga
    Trim : Elegance
    Engine : Z30DT
    Thanks, will check
  1. air bag warning
    By shaun 37 in forum Vectra C / Signum Troubleshooting
    Last Post: 16th June 2014, 10:31
  2. Warning to all men!
    By Jim Bob in forum Comedy & Humour
    Last Post: 14th February 2011, 22:58
  3. ******warning*****
    By peter-gsi in forum General Chat
    Last Post: 15th December 2010, 18:23
  4. Warning...................
    By lizard in forum Electrical & ICE (including SatNav)
    Last Post: 5th October 2009, 18:20
  5. Oil Warning - How far can I go?
    By aaruck in forum Engine & Drivetrain
    Last Post: 30th October 2008, 08:55
vectra c not starting esp cdc lights on
vectra c esp light and cdc liggt on
