Thread: aerial base
    Regular Member coooky's Avatar
    May 2011
    washington
    StatsVehicle Info
    Default aerial base
    Apart from the genuine base from the stealers is there any other base that will fit the vectra that has a washer jet ??
    another question is do you need the rear washer to work to pass the cars mot stupid question but if not im thinking of a shark fin type and removing/blocking the pipe
    thanks in advance
    gwent
    StatsVehicle Info
    Hi best stick to the vaux aerial base as I did do the shark fin mod but could not get a signal so went back to the vaux one .
    Aug 2010
    york
    StatsVehicle Info
    what sort of price are new ones.....
    gwent
    StatsVehicle Info
    About £34 from autovaux all depends how many wires that comes from the base as there are non amp ones and amp ones I ordered the wrong one the amp one so I had to run wire from cigarette lighter to the base .
    Aug 2010
    york
    StatsVehicle Info
    Thanx !!!!!
    May 2011
    washington
    StatsVehicle Info
    so i might be best ordering the amp one even if its not needed saves sending it back ??
    as for not getting a signal i dont have a radio in the car atm anyway lol just need to stop the water in the boot
    went out earlier pulled the roof lining down and it was dripping
    think when i replace it i will also silicone the inside around the nut
  1. aerial and base
    By paul.sessions in forum Parts for sale
    Last Post: 21st November 2010, 10:16
  2. Aerial Base
    By tubby in forum Electrical & ICE (including SatNav)
    Last Post: 9th April 2009, 21:31
