Thread: Overheating engine/ cold radiator
    Jul 2012
    United Kingdom
    Default Overheating engine/ cold radiator
    Hi,
    Car:Vectra 1.9cdti (2006)
    Friday the temp gauge soared into the red, so I switched off.
    On further inspection, I have found the following:
    Temp gauge still rising.
    Coolant levels good & system pressurised.
    No coolant in oil.
    Radiator fans operating at correct temperatures.
    Radiator staying COLD throughout.
    Thermostat housing hot.
    Done a search on this, so I'm thinking thermostat stuck closed.....
    Any ideas???
    Regards, DEE
    VIP-Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 Vtec
    Mileage : 64500
    Coolant returning to the header tank when running? There should be from the thin bypass pipe, if not might be a failed water pump.
    Wondering lonely as a cloud
    26 Post(s)
    Vehicle : M5
    Trim : Nothing needs adding
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    Looks like the thermostat as you say is stuck closed or the water pump is goosed but you say its pressurised they normally fail open hence the numerous threads here about engines not heating up don't run it change the stat
    Jul 2012
    United Kingdom
    Turned out to be the water pump.
    The bond between the spindle & impellor had failed, resulting in no drive to the impellor.
    Cheers, DEE
  1. Warm air from engine when its cold
    By Mikey4996 in forum Engine & Drivetrain
    Last Post: 30th November 2011, 20:23
  2. Is My Engine Overheating?
    By Chris SRi in forum Vectra C / Signum Car Chat
    Last Post: 2nd July 2011, 20:30
  3. Stuttering engine when engine is cold
    By chris_sri in forum Engine & Drivetrain
    Last Post: 3rd January 2010, 00:25
  4. Does anyone Blank Front of Radiator off During Cold Spell
    By 67688c in forum Vectra C / Signum Car Chat
    Last Post: 2nd January 2009, 00:05
  5. Topping up engine oil... engine warm or cold?
    By Quinten in forum Engine & Drivetrain
    Last Post: 15th May 2008, 18:39
radiator not getting hot vectra
vectra c radiator cold
cold radiator vauxhall insignia
radiator cold
vectra c over heating still after puttin a new radiator on
