Thread: multipul misfire 3.2 gsi p0300,p0301,p0303,p0305.
    Regular Member rayvo-gsi's Avatar
    warrington
    Default multipul misfire 3.2 gsi p0300,p0301,p0303,p0305.
    Hi guys hoping you can help me on this one.My vec has an annoying misfire that can only be felt on tickover it seems to run fine once going.Ive changed all plugs and new coilpack on rear bank it had a timing belt done 4k ago my question is could the timing on 1 cam be slightly out as its only the rear bank thats misfiring.Thanks in advance fellas
    Regular Member shaunft's Avatar
    May 2012
    mansfield
    does it say which bank its misfireing on
    warrington
    Its missing on all 3 plugs on the back bank 1,3,5 but only on tickover.
    May 2012
    mansfield
    could possable have slipped a tooth on the timing would get it checked but mine misfires sometimes due to low fuel and brings on or flashes eml
    Regular Member DSmiddy's Avatar
    Jul 2011
    Bridgwater, Somerset
    Engine : 2.8 V6T
    Mileage : 50000
    Quote Originally Posted by rayvo-gsi View Post
    I would get it checked mate, I had the same problem not longer after my timing belt was done, I did the same as you, replaced the plugs and the rear coil pack, made no difference. it turned out to the be the timing belt was slightly out.
    warrington
    Thanks for all your help guys it turned out both rear cams had slipped a tooth sorted it and it runs perfect now but i think i might have tightend the tensioner too much due to a whining noise.
    May 2012
    chelmsford
    Thin k I better give mine a good check over
  1. What is causing P0301 - Misfire no 1
    By myveccy in forum Y & Z30DT Specific
    Last Post: 17th February 2013, 09:16
  2. Z30DT Code:P0303 Cylinder 3 Misfire Detected
    By ben_3.0v6 in forum Y & Z30DT Specific
    Last Post: 27th March 2012, 20:48
  3. Z30DT and P0301
    By LeeU in forum Engine & Drivetrain
    Last Post: 6th April 2011, 13:49
  4. P0301 & P0304 misfire
    By tridley in forum Engine & Drivetrain
    Last Post: 27th September 2010, 00:06
  5. Fault code P0301 on 3.2 HELP?
    By jamesr in forum Engine & Drivetrain
    Last Post: 26th February 2009, 17:59
vectra 3.2 v6 misfire 1 3 5
vectra 3.2 v6 low fuel cylinder 1 3 5
vectra 3.2 cylinder misfire on 1 3 5
vectra gsi 3.2 p0300
vectra 3.2 v6 misfiire 1 3 5
p0300 opel vectra c 1.6 2007
opel vectra p0301
