Results 1 to 10 of 21
Thread: Non-starter
    Regular Member Vectra Meldrew's Avatar
    Hertfordshire
    Default Non-starter
    I have a Cdti 120 manual which has been fine till late last night when I parked up for a few minutes and switched off. When I tried to start it I got nothing! ...No click from starter motor, all lights on dash were lit as normal and they didn't even dim when I turned the key as you would expect if starter motor was stuck. I managed to roll backwards down the hill and it bump started in reverse no problem. Tried starting it many times since and still nothing when I turn the key but bump starts no problem.
    Any ideas you knowledgeable lot??
    Regular Member BigWilko's Avatar
    Jan 2010
    Barnsley
    Engine : 3.0 CDTI
    Happened on my old 120. Turned out to be the crank shaft sensor.
    Hertfordshire
    Just been out to check it and it started first time! Switched off and it's back to not starting again
    However, after plugging in the laptop, I have a fault code ...
    B2961 - Switch Position Ignition Key Circuit Malfunction (08) - Not present.
    Hertfordshire
    Seems to be an intermittent problem now (starts about once in every 30 attempts)
    Definitely appears to be ignition switch or key problem and car only came with one key so I can't try the spare
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Have you tried jumping the starter directly to the battery to see if the starter spins? (make sure it's in neutral!)
    Sounds like an issue with the starter, or the relay sticking.
    Hertfordshire
    No Tony, I've not looked at the starter motor as the fault code for the ignition switch has led me to think it's more key related. Tbh the key is quite worn compared to the 2 keys I have for the old vectra so maybe something inside the key is not making proper contact.
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Have you tried spare key?
    What volt is batt?
    What voltage you getting at starter?
    Regular Member C-Owner's Avatar
    May 2011
    South London
    Quote Originally Posted by Vectra Meldrew View Post
    Usually a key problem.
    1. CR 2032 Battery
    2. Key Transponder
    3. Circuit board fault (water damage)
    Hertfordshire
    I replaced the key battery earlier then tried to start car. Wouldn't start. After about 20 turns of the key it suddenly turned over and started. Switched off, tried again... nothing! 10 more turns of the key and it started. Left if for an hour or two then went out to go to work and it started first time. Since then it's started first turn of the key every time!
    Next time it won't turn over I will get someone to turn the key while I check for any voltage to the starter motor so I can rule that out.
    Thanks for the replies, I think this is going to be one of those annoying faults that come and go but at least I have a fault code to work from.
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Can you hear any relays clicking when you turn the key to the start position?
  1. vec c possible starter ??
    By neilb1 in forum Vectra C / Signum Troubleshooting
    Last Post: 8th January 2012, 16:50
  2. non starter
    By marky1 in forum Engine & Drivetrain
    Last Post: 14th October 2011, 17:06
  3. Non Starter
    By andyguthrie in forum Engine & Drivetrain
    Last Post: 9th October 2010, 13:31
  4. starter or DMF???
    By mark82 in forum Vectra C / Signum Car Chat
    Last Post: 27th August 2010, 11:33
  5. starter solenoid or starter cdti 150 help!!
    By veralum in forum Engine & Drivetrain
    Last Post: 27th April 2010, 19:57
