Thread: Rear Signum Light problem problem - help
    Feb 2012
    Kent
    Default Rear Signum Light problem problem - help
    Hi guys,
    I have an issue intermittently I get warning saying all the rear lights are not working reverse, indicator, rear light, brake-light (only one side)
    I have fiddled with the wiring and it works then stop randomly
    The 6 pin connectors look tarnish (attached to the rear light) so I cleaned contacts but still no joy
    Is this common as I'm thinking a new light with fix the issue unless its the black plug its self??
    Any idea which to change first???
    Where can I source a cheap rear light cluster (passenger side)
    May 2012
    Near Grmsby
    If the connectors look tarnished then that could mean they have been arcing, I would guess that the female connectors in the plug have become weak. Try carefully nipping them back together with some long nosed pliers.
    Regular Member STICKY3.2's Avatar
    Jul 2010
    Hertfordshire
    Loose connection = high resistance = heat = tarnishing
    Feb 2012
    Kent
    Cheers for the advice
  1. Wiper Electrical Problem? (Not sticking or cold weather problem)
  2. TC light problem
    By fester999 in forum Vectra C / Signum Car Chat
    Last Post: 25th September 2011, 18:45
  3. Rear Interior Light Fitted - Problem with front now....
    By Leemarksmith in forum Electrical & ICE (including SatNav)
    Last Post: 23rd December 2009, 00:08
  4. Rear Interior Light Problem
    By r.bailey63 in forum Electrical & ICE (including SatNav)
    Last Post: 22nd November 2009, 23:26
  5. rear brake light problem, bulb ok, please help
    By circushead in forum Electrical & ICE (including SatNav)
    Last Post: 14th May 2009, 18:29
