Results 1 to 2 of 2
Thread: 2.2dti fuel pump
    Dec 2011
    leicester
    Default 2.2dti fuel pump
    Hi does anyone know if it is difficult to change a fuel pump on a 2.2 dti engine. i have just brought a donor car and need to change a few bits over. any help would be great. thanx
    May 2012
    county durham
    Engine : 1.9 cdti 150
    Mileage : 145k
    never had much to do with the mechanical side of it but regarding programming I am fairly certain you will need to reset pump before removing from donor car ( car pass needed ) , then reset you pump before removing , then the replacement pump needs programming into your car .
  1. 2.2 direct fuel pump and fuel pressure regulator
    By w111y in forum Engine & Drivetrain
    Last Post: 11th July 2012, 22:12
  2. 2.2DTi Fuel pump assistance please
    By sigtim in forum Engine & Drivetrain
    Last Post: 10th November 2011, 15:24
  3. Bosch fuel pump vp44 2.2dti
    By davesignum1988 in forum Engine & Drivetrain
    Last Post: 12th September 2011, 13:41
  4. 2.2Dti Fuel Pump issue's?
    Last Post: 3rd August 2011, 21:48
  5. Fuel pressure sensor/fuel pump failure list following Watchdog investigation.
    By happychappy in forum Vectra C / Signum Car Chat
    Last Post: 14th January 2009, 13:18
2.2 dti fuel pump removal
