Thread: spanner and battery light on
    Jul 2010
    perth
    Default spanner and battery light on
    hi got a problem today driving home and went to turn corner and lost power steering plus all lights on dash and vdu went off then on again stopped car switched off then started it again same again 5 mins later got home pluged in code reader and got fault code p0563 system voltage high input reset code but battery light and car with spanner still on checked battery has good charge so not battery any ideas what else it could be any info and help is much appreciated.
    11 Post(s)
    If the battery light is on, it's telling you the alternator isn't charging.
    Have you put a multimeter across the battery to see that approx 14.5 volts is present with the engine running?
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    When you say it has a good charge, what is the charge? As above, should be 14.5v with engine running and all electrics off. Does sound like a shafted alternator though
    ---Sent from my iPhone 4 using Forum Runner.
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Alternator is goosed
    Jul 2010
    perth
    well went out today to test alternator with multimeter and battery drained empty so cant start car do u think getting used alternator is wise as cant afford new one this month (tax ,mot,parts for mot).
    Regular Member STICKY3.2's Avatar
    Jul 2010
    Hertfordshire
    Regulator/Diode pack in back of altenator has probably failed causing the battery to discharge, sorry mate sounds like a new altenator required.
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Not worth getting it reconditioned?
    Jul 2010
    perth
    cheers guys for your advise will be new one at end of month.
    Regular Member skidmark1's Avatar
    Sep 2010
    cornwall
    Vehicle : 2.2 Direct
    Trim : SRI
    Engine : YH 2.2 petrol
    Mileage : 85000
    Quote Originally Posted by STICKY3.2 View Post
    Is it not possible just to get the regulator/diode pack and fit that instead of replacing the whole alternator??
    Jul 2010
    Hertfordshire
    Quote Originally Posted by skidmark1 View Post
    Not worth the hassle, there may be other issues causing the volt reg causing it to work under extra load, personally I'd go for a top quality exchange unit or new.
  1. Battery & Spanner Light on.
    By ickleric in forum Electrical & ICE (including SatNav)
    Last Post: 11th September 2011, 21:31
  2. battery light on along with spanner through car light
    By conny in forum Electrical & ICE (including SatNav)
    Last Post: 24th May 2011, 13:45
  3. Battery light and car with spanner icon?
    By johnnyallen in forum Electrical & ICE (including SatNav)
    Last Post: 22nd June 2010, 10:29
  4. Help..Clear spanner light by disconnecting battery?
    By marky2027 in forum Vectra C / Signum Car Chat
    Last Post: 23rd April 2010, 13:01
  5. Spanner light after changing battery
    By gtr1000 in forum Engine & Drivetrain
    Last Post: 10th December 2008, 21:40
