Results 1 to 2 of 2
Thread: Blown a boost pipe off!
    Jul 2012
    scarborough
    Default Blown a boost pipe off!
    My cdti 150 vectra has been missing ever so slightly when on part throttle so after reading a few threads on here I decided to clean the EGR valve out. Did this and went for a blast up the road at first it was ok then seemed to loose boost then went into limp mode showing code 4000 EGR flow malfunction. Reset the code then it did the same again. I decided I would just rev it for a bit see if it would clear itself, so sat there for about 3 mins holding it at 3k revs when the boost pipe blew off. Think it comes from the intercooler as hard plastic then onto rubber to the inlet. The rubber hose blew off the hard plastic one.
    Anyone got any ideas of what my problem is and how to resolve it?
    Jul 2012
    scarborough
    Just one more thing regarding the missfire if you listen out the window when accelerating gently you can hear the turbo whistle almost like a whoosh then it missfire and the sound totally changes.
  1. Boost pipe expanding..!
    By olid2002 in forum Diesel Engine related
    Last Post: 12th August 2011, 03:19
  2. New boost pipe
    By storm in forum Diesel Engine related
    Last Post: 30th August 2010, 20:58
  3. Boost pipe
    By SB3871 in forum Engine & Drivetrain
    Last Post: 15th July 2009, 11:50
  4. Boost Pipe
    By Danwells72 in forum Vectra C / Signum Car Chat
    Last Post: 27th June 2007, 17:31
