Results 1 to 3 of 3
Thread: Aircon seals. Where to buy?
    SAUCHIE
    Default Aircon seals. Where to buy?
    Hi folks I hope I have put this in the correct place. My aircon stopped working and traced fault to stone through condenser. I purchased new condenser but it came without the double oring seals needed for the pipe and airdryer. Can anyone help me as to where I can purchase these seals. Vauxhall only supply the main seal but won't supply the smaller seal that goes on the airdryer side.
    Many thanks
    colin
    Engine : 1.9 CDTi
    Are they not just normal 'O' rings?
    Also have you looked at the guide on how to change it as I think it lists all the part numbers for the seals so you can go back to Vauxhall with the part number.
    SAUCHIE
    No there are double seals which are a brass outer washer type with a rubber insert according the the aircon guy who is going to regas it all after I have replaced condenser. Thanks I will try and find the how to link.
  1. Aircon problems - Not working, if anything air gets hotter turning on aircon???
    By Coupe2T in forum Electrical & ICE (including SatNav)
    Last Post: 30th July 2012, 10:13
  2. Could this be injector seals or??
    By gmclorn in forum Vectra C / Signum Troubleshooting
    Last Post: 18th February 2010, 14:06
  3. Injector seals!!
    By siz1 in forum Engine & Drivetrain
    Last Post: 13th October 2009, 19:20
  4. Change aircon to auto-aircon?
    By um20 in forum Electrical & ICE (including SatNav)
    Last Post: 20th March 2007, 22:12
