Thread: 2.0T not running quite right
    Regular Member GoldenWonder's Avatar
    Durham
    Default 2.0T not running quite right
    I've had a few stabs at getting this sorted but its still not running right in my opinion (2008 2.0t with 40,000 on it)
    It starts every time, but always takes a few turns on the starte to fire up - is that normal for a 2.0t? My 1.8 fired on first turn.
    Once warmed up it has the well know erratic idle but today it spluttered a bit once started up - almost like a slight misfire.
    So heres what I've done in the last few months.
    - New plugs (NGK)
    - New fuel filter
    - New air filter
    - Cleaned throttle body and checked pipes for tightness etc
    - Run through some redex
    - Run through a few tanks of VPower
    - Changed the CTS
    - Put a known working coil pack on each cylinder in turn to see if it helped.
    Nothing seems to make any difference so with the 'delay' on starting I'm beginning to think it might be that the timing is slightly out (loose chain?) but it doesn't misfire in normal driving and if you really floor it will leap away like a scaled cat! (not that I do that often, but would the timing being out not make it misfire etc doing that?)
    I haven't changed the o2 sensors, but its averaging 35mpg on a motorway commute which I think is pretty healthy and I thought a faulty o2 sensor would really affect the economy!
    Is there anything else I can try? I'm a bit OCD when it comes to keeping my car running right!
    South east
    Quote Originally Posted by GoldenWonder View Post
    Increase the idle speed using Tech2 or similar, as recommended by Saab.
    Durham
    Do they specify what the idle speed should be? Seems to idle OK - but 'dip' and recover.
    Full Member Caveman_nige's Avatar
    Jun 2009
    South Coast
    Vehicle : Vectra and a Signum
    Engine : Z18XE,Z19DTH,Z20NET
    there all lazy starters from what i have read so don't let that concern you.
    Durham
    Cheers - thats one thing off my list!
    Jun 2009
    South Coast
    you could try gently cleaning the the lambdas, i don't think they are out of loop until after the choke is off though.. I cleaned mine off with carb cleaner, the second one with vinegar as well then carb cleaner..
    I went through all the bits you have done as well, then oneday mine just settled down to normal idling again.. I do thrash my car regularly though, the old Italian tune up as they call it to make sure it still pulls its weight so to speak..
    May 2011
    bispham, blackpool
    check the injectors take them out clean the rubber seals on them and put them back in the brother in law had the same problem for nearly a year untill we did that and it seems to of cured it he hasnt mentioned it since will have to ask him next time i see him
    Durham
    Is it an easy job to remove the injectors? I haven't done that since my old Carlton!
    I thought about shoving some Cataclean in to clean the sensors but I'm always a bit sceptical of this snake oil stuff
    Regular Member nikroc's Avatar
    Nov 2007
    DERBY
    13 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    I may be a sucker BUT after reading various threads,and allways wanting to get things running 'right' I bought the BG44K fuel system cleaner,as recommended.
    Sourced via Ebay.
    To be fair my 2T has allways run like a dream over the 4 or 5 years I've had her..BUT since putting a can of this stuff in the tank(and Im only halfway through the tankfull/can combo) I swear she's picking up smoother.1st and 2nd gear are noticebly smoother/quicker and the whole expeirience is positive.
    Im that impressed I bought 3 more for friends and family!!!
    Regular Member richy1974's Avatar
    Jun 2012
    leek
    Quote Originally Posted by nikroc View Post
    Sourced via Ebay.
    I just run my on bp ultimate or v power and reset the ecu every 1000 miles
  1. Anyone running LPG?
    By forde in forum Vectra C / Signum Car Chat
    Last Post: 21st November 2012, 08:55
  2. Running on oil
    By dunkymunky in forum Diesel Engine related
    Last Post: 18th November 2010, 08:34
  3. How hot should I be running?
    By Tigger in forum Engine & Drivetrain
    Last Post: 14th August 2009, 16:40
  4. Running in?
    By Messenger in forum Engine & Drivetrain
    Last Post: 30th January 2009, 11:56
  5. running much better
    By monty1 in forum Vectra C / Signum Car Chat
    Last Post: 7th December 2007, 21:55
vectra c 2.0t no power in 1st and 2nd gear
