Thread: ta technix fron height adjustment
    May 2011
    bispham, blackpool
    Default ta technix fron height adjustment
    i might sound a bit stupid here but i bought these http://www.ebay.co.uk/itm/2007693781...84.m1439.l2649
    just fitted the fronts and what i seen on you tube on how to adjust the height on coilovers is you adjust the spring rate damper rate so you can have it hard or firm and then unsrew or screw at the bottom so you screw into the bottom mount to adjust the height
    well the ones they sent me only lets you adjust the spring to hard or firm yes car is slightly lower looks like its about 30mm-40mm lower at the front but carnt seem to lower it any more by adjusting spring
    am i missing something or have the just sold me sports suspension instead of coilovers
    ive sent a message off to seller to ask him does anyone know what i am missing
    Engine : 1.9 CDTi
    The bottom of the spring should be sitting on a 2 locknuts.
    You need to loosen the lowest one off with the C spanner and then use the C spanner to wind the other locknut down to lower the car.
    May 2011
    bispham, blackpool
    I tried that it seems just to make the springs softer which yes dies drop it a few more mm but nothing like the 120mm it should lower
    Sent from my HTC Wildfire using Forum Runner
    May 2011
    bispham, blackpool
    Engine : 1.9 CDTi
    The spring rate wont change as all your doing is moving the mounting seat so lowering it.
    You still have all that threaded adjustment to go yet.
    May 2011
    bispham, blackpool
    Quote Originally Posted by lee gsi View Post
    in the morning im going to wind it right down carnt see it going down to the 120mm they state but will give it a go. at the moment its 22 times i marked the strut and then marked the rings and counted how many times round to get to it where it is at first it was 35 times i lowered it down 13 times and it didnt look like it went any lower
    after watching all the ones on youtube these are totally different and now after reading the ebay add i think it means the damper rate never changes so odds on
    it could be just me expecting alot more than they are will do backs on monday and see how i feel then
    Engine : 1.9 CDTi
    Wind it down the amount that you want the car lowered more.
    Ie if you want it 40mm lower than it is now wind the locknuts 40mm lower.
    Also I would take the 120mm with a pitch of salt as its probably measured when a car is on a brand new spring with a light engine. Also you will probably find the 120mm is the length of the threaded part so you have 120mm of adjustment.
    May 2011
    bispham, blackpool
    Thanks lee will try it in the morning I want it about 20mm to 30mm lower than it is now any lower and I don't think it will get up my drive
  1. Drivers' seat height adjustment
    By andy1103 in forum Bodywork & Interior
    Last Post: 20th June 2016, 13:58
  2. Hi fron rasher
    By Rasher in forum Introduce yourself.
    Last Post: 21st April 2012, 19:04
  3. Replies: 11
    Last Post: 14th March 2012, 13:49
  4. LO or TA Technix coilovers??????
    By Big Red in forum Handling & Braking
    Last Post: 6th December 2011, 12:20
  5. Elite Seat Height Adjustment?
    By SteveBray in forum Insignia car chat
    Last Post: 23rd November 2011, 19:54
ta technix coilovers adjusting
adjusting ta technix coilovers
how to adjust ta technix coilovers
how to lower ta technix coilovers
where is the damping adjustment on ta technix coilovers
ta technix coilovers adjust rear
ta technix adjustment
tatechnix height adjustment
ta technix coilovers for vectra c www.vectra-c.com
ta technix adjust length
