Thread: Fault Codes
    Jun 2012
    Edinburgh
    Default Fault Codes
    Hello!
    I finally managed to get a code reader that works.
    After reading the codes this is what I found.
    Total number of fault codes: 5
    P0135 - O2 Sensor Heater Circuit Open (Bank 1 Sensor 1)
    (04) - Not present
    P1112 - Swirl Flap Stuck
    (61) - Not present
    P1112 - Swirl Flap Adaption Malfunction
    (64) - Not present
    P1666 - O2 Sensor Malfunction
    (0B) - Not present
    P0136 - O2 Sensor Circuit Open (Bank 1 Sensor 2)
    (04) - Not present
    The Lambda sensor wasw changed by me 2 days ago.
    If it says the codes are not present it means that everything is ok?
    Thank you!
    Admin plasma's Avatar
    On the Forum
    271 Post(s)
    Engine : 150
    Mileage : 74000
    correct, not present means they are no longer there.. so clear them down and recheck in a week.
    Plasma's Tech2 services are now partially open and able to provide services
    Come Join our new forum Insignia Owners.com for all your Insignia chat and needs
    Jun 2012
    Edinburgh
    I've done that... I will recheck in a week...
    Thank you!
    Jun 2012
    Edinburgh
    After driving aprox 80 miles the eml light went on again.
    I arrived home and read the codes. One code came back again, but also as not present.
    (61) - Not present
    What should I do?
    On the Forum
    271 Post(s)
    Engine : 150
    Mileage : 74000
    have a search on 'inlet manifold' its where the motor on the inlet manifold moves flaps which alters the airflow at low speeds.. These get gunked up and cause the flaps to stick, if you do a search youll find people have tried to use intake cleaner etc etc but once they get too bad its time for a new inlet... but you need to do a few other checks first like to check to see if the bar is on across the top or if its the actual motor which moves the bar..
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800
    Mileage : 132000
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800
    Mileage : 132000
    [QUOTE=danhariga;1847621]After driving aprox 80 miles the eml light went on again.
    (61) - Not present
    http://www.vectra-c.com/forum/showth...engine+cleaner
    Jun 2012
    Edinburgh
    thanks guys!
    I'll buy some intake cleaner and give it a good spray and see ...
    Considering that the fault code is not permanent maybe it is not so bad....
  1. fault codes?
    By farley2708 in forum Engine & Drivetrain
    Last Post: 5th February 2012, 00:18
  2. fault codes
    By ADAM123 in forum Engine & Drivetrain
    Last Post: 31st January 2012, 19:02
  3. Fault Codes
    By tony100la in forum Vectra C / Signum Car Chat
    Last Post: 10th November 2010, 09:49
  4. Fault Codes
    By cdms811 in forum Vectra C / Signum Car Chat
    Last Post: 15th November 2007, 14:17
