Thread: 02 sensor
    Regular Member richy1974's Avatar
    Jun 2012
    leek
    Angry 02 sensor
    Does anyone know which is best place to get 02 sensor for the 2.0turbo z20net engine
    or anybody who has a part number for said item
    reset the eml but its come back on so i guess the sensor is fooked
    Jan 2012
    Milton keynes
    Trim : M Sport and Design
    Mileage : 38100
    There are a few listed for the Z20NET -
    Position 1 - Ident CA
    Oxygen Sensor with harness - Part Number 55351836 - Range C-41039263 - / C-48034284 -
    Position 1 - Ident CH
    Oxygen Sensor with harness - Part Number 93180669 - Range C-41039264 - / C-48034285 -
    Position 2 - Ident CF
    Oxygen Sensor with harness - Part Number 55353269 - Range C-41039263 - / C-48034285 -
    Position 2 - Ident CJ
    Oxygen Sensor with harness - Part Number 93180670 - Range C-41039264 - 51065673 / C-48034285 -
    Position 2 - Ident CS
    Oxygen Sensor with harness - Part Number 93184704 - Range C-51065674 -
    Hopefully someone can tell you which one...
    http://www.ebay.co.uk/itm/Vauxhall-L...item2c65448cbd
    Looking at £80-100 on Ebay new.
    Jun 2009
    South Coast
    Vehicle : Vectra and a Signum
    Engine : Z18XE,Z19DTH,Z20NET
    or you can get it mapped out with a remap
    Jan 2012
    Milton keynes
    Mileage : 38100
    Quote Originally Posted by Caveman_nige View Post
    You can map out the O2 sensors?
    (Stupid Q alert) Why would you want to do that? Are they not important?
    Jun 2012
    leek
    lost me here car is already mapped has a shinny new exhaust fitted from mij i guess that what caused the 02 sensor to play up. They dont like being messed about with lol.
    Jun 2009
    South Coast
    could me getting confused here as well lol..
    by o2 sensor are you referring to the one of the two lamdas or the EGT sensor? Peeps seems to refer to them all as the same thing when there not.. Lambda 1 is in the top bend of the downpipe just after the turbo but before the cat. the EGT (exhaust gas temp sensor) is in the downpipe just below the cat and was omitted on later models from 2005 onwards. its this EGT sensor that can be mapped out if required and some refer to as 'the 02 sensor'. Lambda 2 sits in the centre exhaust section roughly under the handbrake lever area.
    if the lambdas are playing up you can clean them off with vinegar but don't use a wire brush or abrasive....
    i cleaned mine off a couple of years ago, i replaced lambda 1 and my engine/ecu did not like it, so quickly put the old one back on.. still got that new replacement lambda floating around my garage..
    Jun 2012
    leek
    This is the error codes i got so which one need replacing the one by the handbrake in the center of the exhaust
    OP-COM 100219a - PC based diagnostic tool
    gtc autos
    OP-COM - CAN Communication Window> 2004 (4)|Vectra-C / Signum|Engine|Z 20 NET
    Read Info...
    Identifier: 0x0B01
    Hardware number:55353231
    Motor type: Z20NET
    Part Number:12798178
    Software version number: 55355335
    Hardware manufacturer number:
    Programming Date: FFFFFFFF
    Hardware key number: PPCAN 210
    System description: GMPT 0100
    Type approval number: G03005
    Variant programming: 0x38363332333241413041353130523645
    Alpha code:
    Software Freeze Date: 5®
    Hardware manufacturer system name: Trionic 8
    Software version: FA4Y
    Temperature Index and version:
    ECU variant coding: 0x00007902
    Total number of fault codes: 3
    P0137 - O2 Sensor Circuit Low Voltage (Bank 1 Sensor 2)
    (00) - Not present
    P0138 - O2 Sensor Circuit High Voltage (Bank 1 Sensor 2)
    (00) - Present
    P0420 - Catalyst System Efficiency Below Threshold (Bank 1)
    (00) - Not present
    Jun 2009
    South Coast
    sounds like it.. you could try cleaning it but they are easy enough to replace.. they come with about 90cm of cable as it feeds all the way back to the engine loom. You can of course just cut the old one off and solder the new one onto the old wires about 6inches back from the sensor, i did this on somebody elses 2.0t for them and it worked fine after.
    Jun 2012
    leek
    Thanks mate do u know bet place to get one from ?
  1. Replies: 3
    Last Post: 13th August 2012, 22:25
  2. P0141-04 o2 sensor heater circuit open (bank 1 sensor 2)
    By Mark1892 in forum Engine & Drivetrain
    Last Post: 3rd August 2012, 09:19
  3. Fitting & Installation of ABS Harness & brake Help sensor sensor
    By Elahi_786 in forum Suspension, Wheels & Brakes
    Last Post: 17th April 2012, 20:46
12798178 turbo
